Question about Broan-NuTone Allure QS130SS Kitchen Hood
How to remove grease from fan 'blades' withut removing motor
  • 520 Answers
The fan should come right off. they screw on,- or they have a set screw,- or they have a clip,- or sometimes if they are plastic they just pull off. this is all assuming that you can get to the fan.
Posted on Oct 09, 2010
My downdraft vent no longer removes cooking fumes and smells for days after cooking. We have changed the screens, but still have residue coming from the vent inside the cabinet. Does this vent need to
Remove the motor together with the blower wheel, go to the local self service car-wash and use the engine de-greaser cycle (if not available, buy a can at the auto supply, spray the fan blade and let sit for a while) and get all the grease of the fan blades. make sure the fan blades are cleaned thoroughly. the fan will now ran quietly and will remove all the grease away. in the future, clean the filters often.
Jan 06, 2014 | Kitchen Ranges
My baioniar fan not work properly only swing but not start motor so what can I do . there is no machnic hear that co'z u tel me how ripiar this
I found my own solution for fixing my fan, I took the cover off of the fan by removing the base, and the three screws that hold the cover on, I cold start the fan by turning it on and forcing the blades to turn, But that was the only way it would work. What I found was at the top of the shaft that goes through the fan there is a rubber cap that holds grease it is held on with two screws , The grease in the cup was hard and wouldn't let the fan move freely, So I cleaned out the old grease and put in some new grease that I had here it is grease used for my pool pump motors to keep the seals soft so this grease wont get hard. I put the fan back together and it is working fine. I hope that this works for you. Denis K.
Oct 08, 2011 | Bionaire BT45RC Tower Fan
Is there a means for a technically competent handyman to lubricate the bearings of the lasko wind machine 3300?
The fan and motor are both easily disassembled with a Phillips screwdriver and some gentle force to remove the blades. Try to use even pressure when removing both the blades and opening the motor housing. The only questions are whether to flush the existing lubricant out of the bearings and what to replace it with. If you know what to use it shouldn't be a problem. If anyone could suggest an oil or grease, please do.
Apr 03, 2011 | Lasko 3300 Wind Machine¿ Floor / Box...
Fan does not come on
This will take some work, and some elbow grease, but what happened is the motor bushings most likely seized. Try turning the blades with your hand. If they are stiff, the bushings are seized. What you will have to do is take the fan apart. First by removing the blades, then by taking the motor off of the frame. Then depending on the type of bolts/ screws that hold the motor together, remove them. Then split the motor apart by taking a flat blade screwdriver and sliping it between the two pieces of the motor and turning it so they slip apart. then once the motor is apart, shine up and clean the motor's shaft so it is clcan and shiny. then do the same for the bushing/ beringholes in the motor's casing. then drip some oil in the berings, and on the motor shaft, and put the motor back together. then put it back on the frame, and plug the fan in. turn it on. the shaft should just spin without any help. if this does spin, put the blades back on, and put the guard back on. Then you sucessfully rebuilt the motor and the fan!
Aug 12, 2010 | Lakewood High-Velocity Fan
I have a noisy cooling fan. I have cleaned and removed all the dust from the vents in the compressor compartment, but the fan still make a squeeking sound. Can the fan be oiled or greased or should it...
Is the area between your fridge and freezer smoking hot? Can you smell the rubber seals melting? Does your fridge squeak like crazy? You have an issue with your condenser fan. You can save about $50 by fixing the fan motor yourself. I'm no engineer but this was an easy fix. 1) Unplug the fridge. 2) Take off the lower back panel covering the condenser and fan. 3) Unplug the fan (on the top left from the fan. 4) Slide the fan out of the bracket 5) Take the fan blade off. (This will take the most time and TLC, it is glued on) 6) Take the two screws out of the back of the housing. **The fan motor should be free of the housing and blade** 7) Remove the two screws from the fan motor housing. 8) Pull the shaft out of the motor and clean all parts with some oil and a rag. 9) Make sure all moving parts are well oiled then put the shaft back in the motor housing. 10) Replace the motor housing screws 11) Replace the motor into the fan housing and replace the screws. 12) Slide the fan blade back onto the shaft (I used some super glue to help hold it in place) 13) Slide the fan housing back into place 14) Plug the fan into the socket 15) Plug in the fridge to make sure your fix worked (it may take a minute to kick on) 16) Replace the lower cover
Aug 03, 2010 | Samsung RS2630SH Side by Side Refrigerator
KitchenAid evaporator fan replacement
the correct procedure is to hold the motor n pull the fan blade out holding from the central n removing the clips if any.it should be replaced if its worn out
Jan 18, 2010 | KitchenAid Architect KBFA25ERSS Stainless...
Fan not working
Yes the bearings in the fan motor are bad you get at an a/c supply house for $ 150 to $200
Oct 06, 2008 | Friedrich SL24J30 Air Conditioner
Accutek stand fan just hums, won't turn
That means the bearings are dry and have locked. Simply open the motor cover by removing the screw and pull the oscillation knob by rocking it side by side gently to have free access to the motor.
MAKE SURE THE FAN IS UNPLUG FIRST. Use cream type grease on both ends of the shaft. After applying the grease rotate the blades until they're freely and you feel the blades have released.
Place the motor cover back and the oscillation knob and plug-in the fan. Leave it on HIGH for 10-minutes or more to make the rotor loose with the grease.
Jun 15, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Haeir HRF10 refrigerator
Remove coil on back of refrigerator very gently and support the coil against a kitchen chair or counter. On the back of the refrigerator there is an access panel. Remove 4 screws holding the cover. Remove the bottom of the freezer compartment by removing screws and pulling bottom straight out. Remove Styrofoam panel from freezer by cutting tape along side edge. Once the Styrofoam panel is removed you will see fan blades. O n the front of the fan blade there is a spring. Pull the spring off by pulling straight forward with pliers or fingers. Remove the 3 screws holding the fan motor to the refrigerator in the rear access panel. The Motor should now be free. Unplug the plug from the connector by lock latch and pulling straight up. Now you must free the fan blade from the fan motor. Grasp the fan motor and pull straight out. This fan blade is really hard to get off. Try separating the two halves of the blade, where you removed the spring, with a screw driver. The motor is available from Repairclinic.com. Good luck.
Mar 01, 2008 | Haier HRF10 Top Freezer Refrigerator
Broan-NuTone Allure QS130SS Kitchen Hood Logo
538 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Phil Lovisek
Phil Lovisek
Steve
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
