Question about Norelco 3601 X Electric Shaver
Norelco 3605X Electric Razor Charge Time
I assume my razor is very similar to the 3601X therefore the charge time after complete discharge ought to be the same. How long should it recharge? My email address is: charlesalley@peoplepc.com
  • challey Jul 01, 2008
    I have not had a response to the above question. My email address is included. I will appreciate a response.
2 Suggested Answers
kol_easley
  • 20 Answers
SOURCE: Charging 3605X
1HOUR
Posted on Jul 27, 2008
brector3
  • 1580 Answers
SOURCE: looking for replacement heads for
You will find replacement heads for model 3605X at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq4-plus-replacement-heads-also-fits-eltron-p-248.html
Posted on Dec 05, 2010
How do i change the battery in panasonic es-rt51 electric shaver
Panasonic ES-RT51 battery problems?
If your razor battery runs down after only a few shaves e.g jumps from 60% to zero Let the razor completely discharge by leaving it switched on until the blades stop moving completely. (This can take over 24 hours so be patient) When they are stop moving recharge the battery and you will find the battery will charge and discharge just like new!
(This may take a couple of discharge cycles). Only charge the battery when it is flat after this and the problem SHOULD not reoccur.
Terence Saunders
Jan 01, 2014 | Electronics - Others
How do I revive a Hilti 36 volt battery from a TE6 nicdm
There is no way to revive a rechargeable battery once they go bad. Rechargeable batteries have a lifespan that is affected by how many times they have been discharged and recharged and how fully discharged they are between recharges. Most batteries will last longer if they are fully discharged before recharging and allowed to cool completely before recharging, heat being the main culprit to their longgevity. They will eventually reach a point where they will not charge anymore or if they do they will not hold a full charge for any appreciable time. The best test for the batteries ability to take a charge is to completely deplete the battery either through working it or sitting on the couch with the trigger pulled until it stops working completely, let it cool down then put it in the charger. If it charges, use it to see how long it lasts. If it dies quickly it needs to be replaced.
Dec 29, 2011 | Drills
I was given a norelco 3605 shaver in excellent condition (used) without instructions and would like to know the charging procedure and duration (the amount of time it takes to fully charge the razor). Is...
The manual says to charge for 16 hours if it has not been used in awhile. They say nothing about it over charging, but the batteries need to be used and let discharge through shaving. A fresh/new battery is supposed to last about 2 weeks before needing a recharge. I think keeping them charged all the time cuts down on battery life.
Jun 07, 2011 | Norelco 3605 X Electric Shaver
Ijustbought a newbattey for my acer aspire 6920 laptop. Iinstalled it and it said 61% available, I let it charge all night and all day untiljust now 7pm. and id still says 61% and charging . the old one...
First try a REFRESH by discharging it COMPLETELY than re-charging it COMPLETELY (do that 4-6 times) nice week end project ha!, than if it still won't charge completely ASK FOR A REPLACEMENT OR REFUND... (if it's new it should be under waranty)
May 26, 2011 | Computers & Internet
Norelco shaver sudden power loss
I hope you are observing the following:- Recharging only when the batteries are almost completely empty. Continuously recharging or continuously using as a corded razor will reduce life of batteries Charge only when the indicator in charge meter starts blinking. It appears that your batteries are gone. Hope you have replaced the batteries with the new ones. Use a good brand
May 14, 2010 | Norelco Quadra 7885 XL Electric Shaver
Razor charged but not running
You didn't specify how old you model is.
Generally I would say, the battery is failed.
You might try taking it to whereever you bought it and politely ask for a replacement. Its also a good idea not to leave these in cars during sub freezing weather.
Apr 09, 2010 | Norelco Cool Skin 7775X Electric Shaver
Norelco 1090x arcitec razor.
Norelco no longer has authorized warranty repair centers. I suggest calling Norelco customer service at 1-800-243-3050 for assistance
Mar 11, 2010 | Norelco Arcitec Electric Shaver -...
Why is it that it takes around 12 hrs for my laser mp4 to fully charge?
Your internal rechargeable Lithium battery must be getting old and therefore starting to loose its capacity to charge completely. Another symptom is significant reduction in Total play time and faster discharge on standby.
Dec 28, 2009 | Laser MVP-1G MP3 Player
Norelco 3601 X Electric Shaver Logo
344 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Robert McClure
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
