Whirlpool aqua steam awo/d as148 fault f:06 - Washing Machines
dutchman05
  • 487 Answers
SOURCE: have just got new
Please register and forward this question to them
WHIRLPOOL
If this does not help you than Email direct whirlpool_customerexperience@whirlpool.com
If it is codes 32 it will be the pressure switch which is not working right
Posted on Jul 20, 2008
jonniewalker
  • 1031 Answers
SOURCE: fault codes f 13 Whirlpool Washing Machine AWO/D 5716
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Posted on Jan 29, 2009
  • 10865 Answers
SOURCE: Fault F07
F07 Motor control unit error The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the MCU
• Check the Drive Motor
• Check the Wire Harness
Replace failed component.
Posted on May 20, 2009
  • 27 Answers
SOURCE: whirlpool gb awo 3551 is not spinning of its
it cant work
Posted on Feb 21, 2010
TheMobilian
  • 8220 Answers
SOURCE: Machine stopped showing F11 as fault on screen. No
F11 Motor control unit internal failure MCU board failure or broken wire. Check that harness for loose connection to that white box on the left. That is the MCU. Get a tech manual for your machine HERE fe0b7a2.jpg4c1535c.jpg
This might just be a loose connection. The MCU pictured here is the white box on the left and above
The tech sheet is behind the kickplate also and it will give you the data you need for your codes.
Posted on Jun 02, 2010
Why has my Perfectcare aqua stopped emitting steam
You should hear the boiler heat up the water. When you pull/push the trigger, a pump should be activated and steam should be released. If the pump is not working, it could be a defective capacitor according to this article:
https://lieven.kks36.be/2016/06/11/philips-perfectcare-aqua-does-not-pump-solved
A spare capacitor should cost you no more than a few dollars, just find somebody with electronics/soldering repair skills.
Aug 31, 2014 | Irons
Whirlpool aqua steam 6 door won't open tried resetting, cleaned out filter can you help ?
We had the same problem. Mechanic had to come and replace the lock. Took him less then three minutes to open the door, remove the old lock and put a new one in.
Jun 30, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
Red symbol washing machine water light
I would check to see if the water pump has not become blocked as it needs to empty the water out before it can advance to the next cycle mabe a wire has come off the pump ,please unplug the machine first eric
Dec 25, 2017 | Washing Machines
Error F6
Hi
Might a problem with the MCU [Motor Control Unit].
Try changing the Motor Control Unit and the wire harness to the motor.
Feb 29, 2012 | Whirlpool Dishwashers
AWO 3551 have a FP fault . help
thanks for your advice. I have an AWO 3551 Whirlpool front-loading washing machine. It works but I think it's highly likely that the filter needs a clean and is long overdue. I've opened the front plate and unscrewed the plastic cover but the filter doesn't come out at the same time. It seems pretty stuck and there is nothing to get a purchase on (unless I get pliers and turn counter clockwise - but slightly concerned that might break it...?) Any suggestions of how to make it 'come out to play'?!
Feb 21, 2012 | Whirlpool Washing Machines
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
WHIRLPOOL AWO/D 8500 WASHING MACHINE DOES NOT PUSH THE WATER THE OUTSIDE OF IT
WHIRLPOOL AWO/D 8500 WASHING MACHINE DOES NOT pullTHE WATER THE inSIDE OF IT
Feb 08, 2011 | Whirlpool Washing Machines
Hi, my whirlpool aquasteam 6th sense washing machine has a fault, its flashing a red symbol on the screen . . what is this?
The F05 fault is nothing to do with what soaps you use.. Its a little red wire located at the front bottom centre of your aquasteam washer that has come lose or detached. A task to get to it but pretty easy and dodgey repair men would have your pants down for such a simple thing
Dec 11, 2010 | Whirlpool Washing Machines
Washing Machines Logo
243 people viewed this question
Top Washing Machines Experts
