Question about Micro Solutions (212010-USA-INT) CD-RW/DVD-ROM (Combo) Burner
Hello, I have a backpack 212010 and I cannot connect to the USB. I should say, the device is not even showing up in Windows... any ideas, please?
Innotab 2s can't connect to computer via USB.
try another USB cable/usb port. if that doesn't work: For windows--check under device manager>>disk drives>>look for vtech nand1>>right click--uninstall>>unplug the toy>>plug it back in>>turn it on>>try to access Learning Lodge again. For Mac>>open Disk Utility while toy isnot connected to toy.>>plug toy to computer>>turn it on>>look for anything that says vtech.if you do go to Learning Lodge--send error report--call vtech
Mar 29, 2013 | Vtech InnoTab 2S Wi-Fi Learning App Tablet...
The USB port on my DELL Latitude C400 does not recognize the mouse
try to use otehr usb ports on your computer. check if the light on the bottom of the mouse lit up. open device manager. under mouse - delete otehr mouse components then restart computer.
Mar 08, 2010 | Dell Latitude C400 Notebook
8330 show no driver on desktop
Hi, When the BlackBerry device is connected by Universal Serial Bus (USB) cable to the computer, it is not detected as a BlackBerry Device on the Windows Device Manager. Universal Serial Bus controllers does not show any BlackBerry device, even though it has already been connected to the computer.
It is because Blackberry Desktop Manager drivers are not registering with the Windows operating system.
To resolve this issue,
1) Uninstall and reinstall the BlackBerry Desktop Manager.
2) Connect the BlackBerry device to another desktop computer to determine if the issue could be related to USB port hardware.
3) Update the BlackBerry device drivers manually.
I hope this information will help you.
Nov 14, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Not connecting to laptop
Hello!
Please consider the steps given below to troubleshoot the issue while connecting the Camera to the HP Computer using a USB cable.
(i) Before connecting the Camera to the Computer, first initialize the Camera to the original factory settings by following the steps given below:
(a) Turn ON the Camera then press the Home button to display the home screen.
(b) Select Settings with left/right arrow on the control button.
(c) Select Main Settings 1 by using up/down arrow on the control button.
(d) Next, select Initialize and OK.
Performing the above steps will reset the Camera to the original factory settings. After resetting the Camera to the original factory settings, turn off the Camera and remove the battery pack then press and hold the power button for 30 seconds.
(ii) Then, reinsert the Battery pack and turn ON the Camera and press the Home button. Select Settings using the left/right arrow on the Control button.
(iii) Next, select the Main Settings 2 option then select "USB Connect".
(iii) In the USB connect, please select the "PTP/MTP" option.
(iv) Next, connect the Camera to the Computer using the supplied USB cable to get it recognized. Please make sure that the Computer is recognizing other USB devices when connected to it.
If the Computer still doesn't recognize the Camera then check in the Device Manager window for any exclamation mark.
Please press the Windows logo on the Keyboard and then press the "R" key while holding down the Windows logo key to open the Run dialog box. Then, please type "devmgmt.msc" in the Run dialog box and click OK to open the Device Manager window. In the Device manager, click on the plus sign next to each category and check for any exclamation mark, if there is any then right click on the device and click uninstall. After uninstalling all the devices with the exclamation mark in the Device Manager, please restart the Computer with the Camera remain connected.
After restarting the Computer, the Camera should be listed in the Computer window (windows logo+E key) as a removable drive.
If the issue persists even after performing all the above steps then the issue may be related to the Operating System. In that case, you may try reinstalling the Windows.
Aug 22, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
Micro solutions Back Pack
It's a standard DB25 pin cable. Male on one end female on the other.
What's the voltage of the power supply for your unit? Mine is missing the power supply. (kids)
May 17, 2008 | Micro Solutions (212010-USA-INT)...
Drivers
I need a driver foe a MicroSolutions Backpack Model 212010 any help would be great. Thank You
Nov 22, 2007 | Computers & Internet
My printer just wouldn't turn on
Good troubleshooting. Disconnect your printer from the PC and try the following:
Go to "Control Panel" -> "System" and click "Device/Hardware Manager". Check that "Show Hidden Devices" is checked inside "Options" and delete the USB ports it has listed, restart windows to have it re-install them and connect your printer. does it show any life signs?
Oct 15, 2007 | HP PSC 1610 All-In-One InkJet Printer
Problem installing the device,keeps restarting the pc
You will probably have to install Service pack 2 to overcome this problem, which you should install for security reasons anyway. If a driver came with the DVD writer, this should generally be installed first, then the writer connected into a USB port.
Jan 03, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Micro Solutions (212010-USA-INT) CD-RW/DVD-ROM (Combo) Burner Logo
Top Micro Solutions Computers & Internet Experts
Tom Chichester
Bill Boyd
Are you a Micro Solutions Computer and Internet Expert? Answer questions, earn points and help others
