Question about Citizen CT-S300 Printer
The device will not close, It looks like there are two teeth sticking out on the inside that is not allowing the door to close. any ideas? We really need some help here. THanks . John
The solution to this problem is not really intuitive, but pretty easy. The small blade inside the CT-S300 occasionally gets stuck and must be manually retracted. You will need to obtain a small Philips-head screwdriver. Insert the screwdriver into the "cutter lock release fitting eye-hole" located on the right-hand side of the unit. Crank the screwdriver to the right several times to retract the blade. Look down inside the unit as you crank
Posted on Oct 11, 2010
Rear AC / heating thumping sound
Yes the noise can be gear "jump" over, the teeth don't break since they are nylon in most cases. This is most often caused by a sticking/warped air temperature control blend door.
Apr 20, 2017 | 2004 Ford Expedition
Everytime intry to print it keeps coming up as paper jam or open/close door. which there is no paper jam and door is closeed
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 19, 2010 | Samsung CLX2160 Multifunction Color Laser...
I have a Sony Optiarc AD-7640S that when sticking a disc in it moves it back and forth 3 times then ejects the disc. It does this on any disc inserted. Got any ideas?
guess there is something inside that's struck and is not allowing the disk drive to close fully....
look for some thing inside the drive or
take it to a tech shop and get it fixed
May 05, 2010 | Computers & Internet
When i close the door on my 95 chevy corsica it doesnt close. it just bounces back. please help im a girl and my parents dont know so use small simple words please.
I think what has happened is that the door latch (the one in the door) has somehow closed and won't let the door shut normally.
Here's how it works. The door latch consists of two major parts. One is the short, round metal tube thing that is attached to the car body about halfway up where the door shuts. Inside the door there is a latch in a slot that lines up with round metal tube thing when you shut the door. I think what has happened is the latch has closed, not allowing the door latch to slide over the metal tube thing and close completely. If you look at the latch in the door slot you'll (hopefully) see what I mean. Now how to fix it.
You'll need a medium to large screwdriver and maybe some help from a friend. First, lift the outside door handle like you are going to open the door. Hold it up. Then, with the screwdriver, push the latch in the door slot UPWARD until it clicks and latches.
It is difficult to put this in words but it usually is an easy fix. No damage done to your car (unless you REALLY slammed the door hard numerous times..).
Please re-post with any questions.
Mar 01, 2010 | 1995 Chevrolet Corsica
In my BMW 735 IL my driver side door won't close i opened with the key but i can't close again all the other doors work fine anybody knows what could be the problem? i really need help asap thank you !
the solenoid inside is maybe sticking. another thing to try is lubricating the latch assembly that attaches to the metal "u"at the door jam.
Feb 13, 2010 | BMW 750 Cars & Trucks
2005-Rusted door latch-inside cavity-both rear doors
try spraying them with a pb blaster and allowing them to sit for a few hours, respray every 25-30 minutes. Then when there done spray well with a brake cleaner to remove rust, then allow to dry spray with a wd-40 then a white lithium grease, should do it
Dec 03, 2009 | 2005 Saturn VUE
I closed the cargo latch on the rear door to transport cargo using rope because I could not close the rear door all the way and now cannot release the latch to close the door now that the cargo has been...
if you look at the latching mechanism on the bottom of the door, you will see two metal teeth. If they are close together, you will have to have somone hold the handle like they were opening the door and use a screwdriver to seperate or open the teeth. Then you shold be able to close the door. Hope this helps :)
Jul 08, 2009 | 2007 Jeep Liberty Sport
Chevy Equinox, 2005 - When door opens..radio does not go off
Actually this is the answer, well at least it fixed my problem and for others reading before you go to dealer or buy replacement anything check some wires first.. first my unlock button didnt work driver side, then driver side window quit working and then radio wouldnt shut off..the equinox doesnt have a push button sensor its inside the hinges so its not the sensor...if you open your driver side door and in the jam look for the rubber boot....loosen the rubber boot from the door and from the frame of the car so that you can examine the wires inside there....to my surprise 4 of my wires were ripped in half and 2 of them had previously had an attempt to repair with crimps...so check your wires before you do anything else if your having any of the problems that I was having! Hope this helps, no where did I find the answer I was looking for on any forum, hopefully this is the problem and its a quick fix, just seems like it may be a problem that will continue to happen!
Mar 12, 2009 | 2007 Chevrolet Equinox LS New Cars
Sliding door switch?
Do you know anything about automotive electronics ?
All courtesy lamps are controlled by the generic electronic module (GEM).
The four contacts are not switches , the part you want to replace is the door ajar switch . The door ajar switch is inside the door part of the lock actuator . Those contacts just allow circuit continuity when the door is closed , when you open the door continuity is broken or open . The GEM now know the door is open an will now turn on the dome lights . The door ajar switches stick , try spraying WD-40 into the door latch ,open an closing the latch . If this doesn't fix the problem you will need to take the inside door trim panel off and replace the ajar switch .
Aug 03, 2017 | 1998 Ford Windstar
CD ROM
If the drive door sticks after you have used the paper clip to open it, look under the tray at the drive teeth (if any). Apply a liberalm coating of general purpose grease to the rwo inches of teeth at the end of the drive tray nearest you and close the drive door again. Open and close a few times to see if the door is now free. This worked for me on my Dell Inspiron 3100. Try it.
Jun 24, 2008 | Dell Computers & Internet
Citizen CT-S300 Printer Logo
470 people viewed this question
Top Citizen Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tejodhar Atreya...
Tejodhar Atreya...
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
