Question about Dishwashers
Dear sir, I have very old Gorenje dishwasher type PMS 201.Recently I have changed programmator with new one but problem is the same.When I put knob on 1 and 2 machine is working ok but if I turn the knob to 3 it does not receive water. I have checked both solenoids and theay are ok.Where to look for the problem.Thanks and best regards Nino
  • raic_igor
    raic_igor Sep 24, 2012
    Do you have a user manual for that gorenje pms 201 mashine? I want to know were to put salt? And what is the round compartment above the square one for the tablets? the
  • 1003 Answers
SOURCE: Dishwasher not filling
I WOULD REPLACE SOLENOID AND TIMER
Posted on Jan 18, 2008
yalmer
  • 549 Answers
SOURCE: Hotpoint Aquarius DWF31 Dishwasher Inlet Valve
Please verify that the hose screen is not plugged.
3.8k is good.
Did you try putting your hand carefully on the body of the valve to check for the clicking sound/vibration at the solenoid?
If you here/feel something, you may just have a plug-up.
Otherwise if there is no noise and since the solenoid coil checks out, You should also check to see if there is voltage to the solenoid coil.
The solenoid could also be stuck and a few taps could loosen junk from it.
Always observe safety!
If there is voltage, by putting a meter across the coil terminals, then you do have a stuck or shot solenoid and the entire valve/solenoid assembly should be replaced.
Posted on Feb 09, 2008
  • 249 Answers
SOURCE: BOSCH DISHWASHER Loss of power
check fuse in plug top,if its not that it could be door switch 30 years repairing. Close Ire....
Posted on Feb 23, 2008
  • 1462 Answers
SOURCE: hygena dishwasher
there is a pressure stat but these are reliable. a common fault is the wiring loom broken where it goes round the corner at the bottom of the door. take outer door panel off and inspect the wiring loom for breakage
Posted on Aug 10, 2008
  • 409 Answers
SOURCE: bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Posted on Sep 25, 2008
Washing machines
/manuals/_washing_machines/gorenje.html
you can get the item you need here good luck
Jan 12, 2014 | Washing Machines
Gorenje dishwasher h24. What foes it mean?
need a model Number of dishwasher for proper diagnostics.
sound like heaters bad
Jan 30, 2013 | Washing Machines
Gorenje dishwasher e1 error
I know that this is an old topic but I have exactly the same problem. Did you manage to fix it?
Jan 26, 2013 | Gorenje GV 62110 23 in. Built-in...
Gorenje B 8960 W, shows blinking times only, not
Same problem, anyone knows how to fix it?
Dec 31, 2009 | Gorenje Refrigerators
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Machine don't fill & Control knob don't advance automatically
Every machine is wired differently. It's possible but not likely that it has a fuse in the circuitry. My guess is that the level sensing tube is blocked and the washer thinks it is at the preset level, ior that the sensing tube has a leak in it. Similar to a hole in a straw. The washer can not advance and operate in automatic if its preset is not satisfied. The preset here is wherever you or it sets the level. Once thw washer fills then a contact closes and turns the timer motor on and advances the timer.
Mar 25, 2009 | Dishwashers
Teka Dishwasher DW6 59 FI Electronic. Stuck on rinse and will not operate on any programme
hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
Oct 13, 2008 | Dishwashers
NEFF Dishwasher Model 5623.25 keeps sticking during running
At what point in the programme does it stick, i.e. is it washing or rinsing or draining, does the water get hot?
Oct 09, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
191 people viewed this question
Top Dishwashers Experts
Owen Barnes
