Question about Samsung ML-3561N Laser Printer
No power I used my printer last night and it worked fine. this morning I tried to turn it on but I had no power and suggestions
Sounds like you have a fuse out on the engine control board (PCB) or it needs to be replaced. If you have a meter, turn the printer off and Ohm the fuses with a meter. If they Ohm, the Engine Control board (PCB) needs to be replaced. If they don't, change the fuse.
Posted on Jan 27, 2009
Why Toshiba Satellite A665 Laptop won't start?
Have you tried pressing space bar (maybe its in hibernation mode) ?
or try holding power button for a few seconds (10) then turn it back on.
as a last resort you could try take the battery out, disconnect it from the power adapter, hold down the power button for 30 seconds and then place the battery back in and the power adapter and try powering it on?
Aug 26, 2014 | Toshiba Satellite A665-S6088 16 Notebook...
I have a Toshiba Satellite A665-S6088. The last time I used it was last night and everything worked fine. It works with Windows 8.1, it has for a few months now, never had any problems until now. No...
Unplug the unit from ac power. Remove the battery. Wait a minute. Press and hold down the power button for 30 seconds. (Yes, I know, nothing will happen visible). Replace battery. Plug unit back in. Now try the power button and see if the unit resets. Sometimes this helps when all else fails especially with a computer which has "hung up" like yours. Let me know if this worked!
Aug 26, 2014 | Audio Players & Recorders
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
Last night the tv was fine i turned it on this
Unplug 20 minutes. Make sure there is adequate ventilation around the set.
Try with the original manufacturer remote to view setup menu.
Power outages come at night. This sometimes resets the TV and other devices. .
Mar 25, 2010 | Insignia 42" LCD Flat-Panel HDTV
Lost tranmission capabilities on one of the units, is there a way to reset. Last night it worked fine, turned of at night, tried to use this morning - no output!!! Any suggestions? Model T5420
The only way to really reset this is to remove the power/battery for 8 hours, press power button for 3 seconds, then wait 1/2 hour. Then try it again.
If you need a manual for this radio, you can view it here:
http://www.motorola.com/mdirect/manuals/T5320_T5410_T5420_User_Manual_E.pdf
Nov 15, 2009 | Motorola Talkabout T5420 (14 Channels)...
Last night my Compaq desktop was working completely fine and I shut it down normally using windows. Now this morning the power button wont turn the computer modem on! There is a green light that is...
try to umplug the modem from the motherboard last pci slot on the botom of the case if that works ok if not try new power supply if still not working problably bad motherboard thanks
Oct 13, 2009 | Compaq Presario 5000 PC Desktop
Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
May 30, 2009 | Spectroniq PLTV3250 32 in. LCD TV
Tv won't turn on
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
Jul 08, 2008 | Televison & Video
Samsung ML-3561N Laser Printer Logo
177 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
