Question about Frigidaire FWS833A Top Load Washer
Good afternoon! We have a Frigidaire top load washer, model # FWS445RFS2. The tub continuously fills with water and we must manually stop the washer and then turn the dial to spin & drain. It cannot complete its cycle on its own without overflowing. Do you know the cause and if a replacement part is available? Thank you. Joe & Janet from RI.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
Joe, remove panel to get access to outside of outer tub. You will see a "bell" with a soft 3/8 clear line coming from it. That is your water pressure hose and it goes to a switch in the control panel. Remove one side from the bell housing, outer tub, and check for gookus. Clean out all obstructions. If there isn't any obstruction in the line, you need a new pressure switch up in control panel. There is a small chance that there is something on the inside of the outer tub which is obstucting air bell but I don't see this very often. Hope this helps,
Rich
Western Appliance Repair
Appliance Repair Nampa
Posted on Oct 09, 2010
Tub fill line leaking
Good Afternoon Friend,
I understand that the washer on your Frigidaire laundry center, model# FEX831CS, is leaking at the back of your appliance. I also see that the dryer is in the way of accessing the line that is leaking. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to change the line with ease. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire FEX831CS Top Load Stacked...
Affinity top loader
I understand that your Affinity washer starts to fill with water and stops, while the counter continues counting down. I also see that nothing is happening while this is going on. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire Washing Machines
My washer want stop filling up and when I should the machine off the water runs in the floor
I understand that your Frigidaire washer, model# FWS833A, will not stop filling. I see that you shut the machine off and the water runs onto the floor. I suggest shutting the water off at the inlet. From there I would contact your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the water will not stop filling your washer. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire FWS833A Top Load Washer
Frigidaire gallery top load washer
After 13 appliance years, your washer is a candidate for replacement.
Aug 08, 2017 | Frigidaire CWS3600AS Top Load Washer
Machine keeps filling up, replace pressure switch, still nohting, keeps filling up?
Hello dwl770 - If your washer won't stop filling up with water and overflows the tub, check for one of these problems:
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off and on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
2) There could be a problem with the water level switch. Call in a professional.
3) There is a pressure switch hose that is attached to an air dome. This switch tells the washer that there is water in the tub and allows the agitator to start.
- Remove the control panel and you will notice a small hose. See if it popped off of the air dome. If it did, secure it with a zip tie.
If water flow continues, but drains out immediately, then raise the drain hose above the highest water level line of the tub. Do not seal the drain hose to the discharge pipe. This could cause a siphoning action.
Sep 30, 2012 | Frigidaire FEX831CS Top Load Stacked...
My Frigidaire GLWS1339CS1 fills but stops about 2 inches from the top? It has done this since I bought it and otherwise works fine. A tech came out and told me to fix it would cost more than buying a new...
The washer will not fill all the wayto the top.yourmachine is functioning properly.when you have an empty tub and put it on super load and fill it up there should be 12 to 14 inches of water in the tub. that is the normal operating settings for your washer.
Oct 03, 2011 | Frigidaire GLWS1349A Top Load Washer
I have top load washer, model #FWS445RFS2 that is leaking at the bottom where the motor mounts to the tub. Is this easily repaired?
this could be the main seal which would make this repair expensive, if it coming out the centre of rotor cap on the direct drive motor
Dec 21, 2010 | Frigidaire Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Mar 01, 2008 | Frigidaire GLWS1233A Top Load Washer
Frigidaire FWS833A Top Load Washer Logo
239 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
