Question about Stanley Bostitch Rn461 Gun Coil Roofing Nailer
After 15 or 16 coils, it would not fire. took top
After 15 or 16 coils, it would not fire. took top off of unit and pressed down on the Top internal assembly, Fire for a while and then wouldn't fire again, did same repair and it work for a short time until job was finished
    President:
  • Stanley Master
  • 1,388 Answers
Look on ebay for rebuild kit # RN46-RK , this kit has all the parts needed to restore to like new. The kit is easy to install and should last for many jobs to come. Be sure to oil the nailer once or twice a day with a few drops or bostitch oil or any nailer oil. It is sold a Lowes for about $3. Good luck
Posted on Oct 10, 2010
Fires first nail will not fire second nail
Ez test. With nails removed, and door open driver should be at top of cylinder. If driver is down replace piston oring. If driver is up, lightly strike nose of gun against softwood. The driver should stay at top. If driver drops with light tap replace piston oring. If driver stays at top dry fire the nailer against softwood. The driver should hit the softwood leaving a mark and return to top. If driver stays down or does not travel all the way up pull the cylinder and make sure checkband is installed. Checkband is oring or rubber band covering series of holes on lower part of cylinder. Good luck
Jun 21, 2015 | Stanley Bostitch Coil Framing Nailer
Change german language to english
To modify the language on the Fire HD2 and Fire HDX:
Step 1
Swipe down from the top of the display screen and then tap Settings
Step 2
Tap on the 5th object from the top Device
Step 3
Tap on the 4th object from the top Language
Step 4
Tap on the 3rd object from the top English - United States
Jun 09, 2014 | Amazon Kindle Fire HD
Change language to english
Step 1
Step 2
Step 3
Step 4
New plug no fire in the ingintion
The ignition unit can fail at any time, before replacing try removing the top cover and pulling the plug leed away from the cylinder, i have seen the leed wear against the cylinder and short out,also check the wires that go down to the unit, these can also short out, it is not a simple task to change the ignition unit, you need to have all the from end off the machine to get to it
Oct 28, 2012 | Husqvarna Forest & Garden 125l 18" Gas...
Gun will not shoot nails completely;no matter what wood,thickness,etc.they drive all but 1/2"
May be due to broken tip. Easy to check. Remove nails and leave door open. With door open, lightly tap the nose of the gun against coiled rubber hose or soft wood. The driver should stay at top position. If driver falls to bottom of the cylinder, replace piston oring. Now press nose of the gun against old coiled up air hose or soft wood and squeeze and hold trigger. The gun will fire and the driver should stay in the down position untill you release the trigger (if not single fire trigger, if single fire trigger remove trigger and press the trigger pin with finger). While the driver is down, make sure that the tip extends past the nose about 1/4 inch (if air leaks past the nose in this position, replace lower bumper). If the driver does not extend past the nose, replace driver. Good luck
Jun 24, 2011 | Stanley Bostitch N75c1 Coil Sheathing...
94 Fatboy, I replaced the coil and ignition, still no spark in the rear cyl, top winding. This bike is a Calf. model. Thanks ............ Dennis Sailor. Cocoa Fl. Steves Cycles...........
By the way you're talking, the bike is equipped with a single fire ignition. Your use of the term "top winding" indicates that there is a "bottom winding" or two windings on the coil. A single fire coil will have three small connections on it. A dual fire coil will only have two primary connections. In the dual fire system, both spark plugs fire at the same time where they fire individually on the single fire. Please check the ignition system out further and tell me if it's a stock ignition system or some type of aftermarket system. Either way, no spark to the rear cylinder indicates a bad ignition unit.
Good Luck
Steve
Nov 14, 2010 | Harley Davidson FLSTF - FLSTFI Fat Boy...
I have took all the leads off from coil to plugs and forgot the set up on suzuki gsx600f Hreg
If you are sitting on the bike the left coil has an orange/white wire on the top and a white wire on the bottom.The HT leads go to plugs 1 4.The right coil has an orange/white lead on the top and a black/yellow wire on the bottom.The other HT leads go to 2 3.It doesnt matter which HT lead goes to either plug as thboth HT leads on the same coil fire at the same time (wasted spark system).Hope this has helped or you have already sorted it out.
May 14, 2010 | 2008 Suzuki GSX-R 600
Coils will not fire
Check for a defective ignition unit (IGBT on top of the coil unit). Check for voltage output from the ECM.
Jul 13, 2009 | 2002 Suzuki Vitara
How do I put grill down when finished using?
You have to step down on the petal in the back of the grill, place hands on each side of the top of the grill and press down hard..took us awhile to figure this out. We just did not push down hard enough. Hope this helps.
Jun 10, 2009 | Thermos Grill2Go Fire+Ice
Cant lower it when press on pedal
You have to push down on the top of the grill..hard, it took a lot of pressure to push.
Jun 09, 2009 | Thermos Grill2Go Fire+Ice
Stanley Bostitch Rn461 Gun Coil Roofing Nailer Logo
220 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
