Question about Sharp EL-1801P Calculator
Ribbon installation how do i put the ribbon in the sharp el-1801v
  • artscroll18 Aug 19, 2008
    how do i install the ribbon for sharp el1801p III?
  • neener86 Oct 22, 2008
    DID ANYONE EVER FIGURE OUT HOW TO LOAD THE INK ROLLER BEFORE I JAM THIS THING IN THE RIVER!?
I searched this online, and have found the following instructions:
1) Set the power switch to OFF
2) Remove the printer cover
3) Remove the ink roller by turning it counterclockwise and pulling it upward.
4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
5) Put back the printer cover.
Posted on Dec 29, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
There is no manual available for this model online.
However, there are two basic methods for Sharps. Always make sure you are puting in paper that has been cut cleanly with scissors, not torn, as this can ruin your printer. If you have a slot on the back of the machine, just under where the paper roller typically sits on the holder, with the calculator off feed the paper in that slot (rolling out from the bottom). Then turn the printer on, and hit the feed to advance the paper into the printer.
If there is no slot on the back, you will see that the opening where the paper comes out from the top is "subdivided", and when it has printed, it is coming out of the front partition of that slot. Make sure the printer is off, feed the paper into the back portion of the opening, rolling from the top. Then turn the printer on, and hit the feed to advance the paper into the printer.
Either method should solve the issue exactly, and once the paper has fed in, then place the roll onto the holder. You're set!
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 08, 2008
That's for the paper, not the ribbon
Posted on Sep 03, 2008
2 Suggested Answers
  • 566 Answers
SOURCE: WHAT KIND OF RIBBON DOES THE SHARP EL-1801V USE
Ink roller type EA-772R
You can find it in any good (refer your machine make and model). There are compatible roller with different references. Also check online (do a gGoogle search or check Amazon.com and you will find several links fopr different seller.
Note that the same type of ribbon is use by diffrent calculators, evem from different brands, so lok for the image of the print roller to see if it looks like t he roller of your machine)
Posted on Jul 25, 2009
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    How do you put the adding machine tape into the Sharp EL-1801V Adding machine?
    Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
    Mar 08, 2010 | Sharp EL-2630P Calculator
    WHAT KIND OF RIBBON DOES THE SHARP EL-1801V USE AND WERE DO I FIND IT?
    Jul 16, 2009 | Sharp EL-1801P Calculator
    Sharp EL-1801V Calculator
    Change the switch to Rate Set, then input the mm.dd.yyyy then the clock/time button then hrs (military time).minutes then clock/time button.
    Apr 02, 2008 | Sharp EL-2630P Calculator
    Sharp EL-1801V 12 Digit 2 Color Printer
    if your trouble is repeated after you switch the calculator off and on again your printer needs service in workshop.
    Nov 01, 2007 | Sharp EL-2630P Calculator
    Sharp EL-1801P Calculator Logo
    988 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    jasbo
    jasbo
    Adorjani Laszlo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
