Question about Dell XPS 400 PC Desktop
Dell xps 400 continues to randomly sod and reboot even after full reinstall. Scanned for malware, replaced hard drive, tested all hw components with Dell diagnostic utility. Thought it was powersupply related but new ps had same results. Not sure if it is malware related but at the kernel level or hw/driver related.
    President:
  • 3,278 Answers
Hello.
If you did all of the above, the only other components are memory or motherboard issue. Couldn't be malware if you reinstalled the operating system.
Something is causing it to overheat. Try removing the memory and test each module at a time, first.
Hope this helps.
Posted on Oct 09, 2010
Xps 400 6.0 gb/s hard drive upgrade wont work
Did you initialize the drive in control panel, administrative tools, computer management, disk storage?
Mar 03, 2014 | Dell XPS 400 PC Desktop
Dell XPS 400 monitor dont show
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free Restart your computer then reinstall it this should activate found new hardware wizard Check the vga lead for secure dust free connection or try another vga lead. Hope this helps.
Jan 09, 2013 | Dell XPS 400 PC Desktop
After I reset Dell XPS 400 to factory settings, it now has a dark screen after Microsoft Windows screen shows up. I do not have the original CD. What can I do?
Try to boot into safe mode by holding down the F8 key while booting.
If that does not work, it may be evidence of a faulty hard drive (C:).
If your hard drive is broken you need to replace it with a compatible drive.
Hold on there! This machine dates back to 2005 and is probably not economically repairable. You can buy a brand new and far better system for not too much, or if you really love this model buy a refurbished machine for perhaps $150 on an online auction site.
Oct 23, 2012 | Dell XPS 400 PC Desktop
Squealing Dell XPS 400
Check the power supply sounds defective
Aug 07, 2012 | Dell Dimension XPS 400 PC Desktop
After a memory upgrade my dell dimension 3100 frequently shuts down whilst browsing then restarts
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot
hope this helps
Jul 04, 2012 | Dell Dimension 3100 PC Desktop
The sound on my dell xps m140 does not work. All drivers are loaded but no sound
Had the exact same problem with exact same computer. Do the following:
1. check for virus, spyware, malware, etc.
2. uninstall driver and reinstall.
If you continue to have problems, check for sound using headphones or external speakers. If this works, order a set of speakers online and replace them. If this does not work then it's your sound card and for that you might need a pc repair tech. Good luck and let me know how it goes.
Aug 25, 2010 | Dell Inspiron XPS M140 Notebook
Dell xps400 branched to the weeds on me. can't even load windows 7 install disk. can't even load in safe mode, runs to where the password screen should come up, then nothing. bad hard drive? drvon, thanks
I didn't understand the first sentence but if you can't even start windows 7 cd then there is a hardware issue (most likely not hdd unless it hangs when it is trying to detect the hard drive) as all the software is on the cd vs reading from the hard drive, if you get to the hard drive and 7 sees it but fails on install then hdd is bad, try finding something called bart pe it's a boot disk you can run windows off of the disk and test the hard drive using western digital diagnostics utility. even more rare you may have a dirty lens in the dvd-rom. there are alot of possiblities.
May 21, 2010 | Dell XPS 400 PC Desktop
I have a Dell XPS 400 with Microsoft XP. It recently shut down with a Blue screen stating that a recently installed driver is possibly bad. I was able to restart the CPU after a while and with in a few...
don't reboot instead reinstall the windows may solve this problem.i recommend ur xps laptop use windows vista ultimate because its have great performance i heard.
Jan 15, 2009 | Dell XPS 200 PC Desktop
Problem installing windows XP
This is going to be either a bad disc or a bad hard drive. Do a hard drive test in the bios, if any part of it fails, then you will need to replace the hard drive. If the hard drive passes, then try a different operating system disc.
Aug 13, 2008 | Dell Inspiron XPS M140 Notebook
Its a Dell XPS 400
There is no way around a bad keyboard, you will need to get a new keyboard to continue.
Feb 19, 2008 | Dell Dimension XPS 400 PC Desktop
Computers & Internet Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
