Question about Coleman Roadtrip Grill LXE 9949-750
Convert roadtrip grill to use a propane tank ]
Noggin
  • 944 Answers
SOURCE: gas grill
If you are sure that gas is coming out of the burner(s) at a roughly normal rate, then the only way it will not light is if you have a bad tank of propane. If you mean it lights but wont stay on, then the safety thermocouples (need to be hot to allow gas to flow) may be faulty - more likely somehow out of position - they can be gently bent back into place but not more than a couple of times. (the way to check if these are the problem is to make sure you are lighting the grill with the control knob in the "light" position - usually held in for a few seconds - this will bypass the thermocouples) If the problem is that the autostart feature is not working, then please post back with details and we can hopefully help identify the problem. Hope this helps - please post again with more info if not :)
Posted on Apr 21, 2007
  • 32 Answers
SOURCE: jenn air 32 in. 4 burner gas grill
HAVE YOU TRIED THE ORIIGONAL TANK? SOME COMPANIES HAVE SPECIFIC TOLERANCES FOR FITTINGS THAT MAY NOT WORK W/ OTHER ITEMS.
Posted on Apr 08, 2008
SOURCE: Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Posted on Jul 17, 2008
gcken
  • 140 Answers
SOURCE: Kenmore Gas Grill 141.155401 issue with Propane tanks
replace the regulator
Posted on Apr 14, 2009
  • 60 Answers
SOURCE: jenn air propane grill conversion
absolute grill & fireplace services 469-774-5561
Posted on Aug 09, 2009
Where can I find a replacement oring for the regulator end that screws into the grill
Your local propane supplier. They are made of a special material so that propane won't react with it.
Jul 12, 2014 | Coleman Roadtrip Grill LXE 9949-750
I have a coleman roadtrip grill. I use a propane screw in canister. When I lite up the grill there is a flame that comes out by the propane cylinder were is screws on the back of the grill. How do I fix...
There is no repair. The canister holder/control valve will have to be replaced. You can contact Weber directly at 800-446-1071. If they don't have it try Appliance Factory Parts http://www.appliancefactoryparts.com/ They have a large selection of replacement parts for all makes & model grills.
Good luck and Happy Grilling!!
Jul 15, 2011 | Coleman Roadtrip Grill LXE 9949-750
I need the part that conects to the propane tank 9949 missing it . what is the part im missing thank you
You're missing the hose/regulator assembly. You can purchase one at any home center or hardware store that sells gas grills and accessories. It runs about $30,00. Take you old one with you for comparison purposes.
Hope this helped you. Please let me know.
Jun 11, 2011 | Coleman Roadtrip Grill LXE 9949-750
Fire code says I cannot use my regular size gas grill with 20 lb tank, so I want to use with 16.4 oz tank. How do I adapt?
Can't different set up. The 16.4 oz is butane. The bigun is propane, 2 different animals. What fire code would prevent you from using one of the new fangled tanks with the safety device witin?
Feb 26, 2010 | Coleman Roadtrip Grill LXE 9949-750
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Cannot conect regulator to small 16.4 oz propane tank
It must have some sort of packing spacer you need to remove from the hose to attach the tank. LOL
Apr 11, 2009 | Coleman Roadtrip Grill LXE 9949-750
Propane tank
Jul 03, 2008 | Coleman Roadtrip Grill LXE 9949-750
No propane to the burners
Check the regulator they may have it installed backwards
Oct 12, 2017 | Coleman RoadTrip Sport Grill 9944-851
Coleman Roadtrip Grill LXE 9949-750 Logo
46 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Treefrog15
Treefrog15
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
