Question about Audiovox BA200 Car Subwoofer
I dont have the input plug for the amp. how can i get it to work without the wire?
TV has a mind of it's own. I turn it off & it turns itself back on. It pulls up the input menu without me hitting the input button. Then it switches between the input options without me hitting...
U have some skills like take things aparts and putting it back together again?Yes?The tv Tuner signal board have problems,might even be the CPU itself have some kind of shorts.The Tuner signal board,that the board,where the incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish Tuner signal board for the replacement.
Oct 28, 2010 | LG 47LG50 47 in. LCD HDTV
Peavey pv-8.5c input problem.. only one input works
HI...
I work on peaveys quite a bit. That one will need service
A guitar amp / stereo tech would do
Check the web near you for someone
rate my help if this helps
Thanks
Apr 22, 2010 | Peavey PVĀ® 2600 2-Channel Amplifier
I put an after market cd player in my 2003 acura 3.2 tl type s. all the speakers are working fine but i am not getting any sound out of the factory subwoofer, it is not working. any idead what i did wrong...
You got to connect the blue amp turn on wire. If still dont work. then you got to find the factory amp find the two wires that sends frequency signals to the amp. You will see a total of 7 wires. So you've got to use process of elimination. Use a multimeter.
1.Constant 12 Volt
2. Ground
3. Amp turn on
4. + output wires going to the + of the subwoofer
5. - output wires going to the - of the subwoofer
6 + input wires going to the radio harness
7 + input wires going to the radio harness
6 & 7 are like the rca's you plug in at the input of an aftermarket amplifier and and on the other end plug in the output subwoofer of the Radio.
So on a factory amp you wont see any RCA's its all wires. Once you find the first 5 just remember the last 2 wires.
If you want your radio to control the gain and volume of the Subwoofer get a long RCA plug it on the back of your radio that says sub output and then cut the other end of that RCA and connect the positive the + input wire on the amp and the negative to the negative input wire on the amp.
If you dont know whats positive or negative just go ahead and connect it and experiment. You will know if your in phase when the subs sound boomy. Then the connections are correct. If it sounds Tinney then the connection is out of phase. solder then tape all connections with black electrical tape. Dont leave any power wires exposed or else cause a short and blow fuses.
Good luck
Apr 07, 2010 | Car Audio & Video
I have a kenwood kdc 233 cd player in my car but the remote wire aint working because i tried hooking up an amp i pit a light power tester on the remote wire but dont work and i dont think the input plugs...
as far as the remote wire a keyed power wire from under dash can be used its the same thing.if the remote wire is working it wont turn on your amp so are you sure thats not why your rcas dont work or have u hooked power to the remote on the amp.
Nov 09, 2009 | Car Audio & Video
How to hook up a pyramid pro plus 4 channel pb-180px without using rca jacks for 6 by 9s
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
Jul 27, 2009 | Pyramid Audio Players & Recorders
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Profile mono 1000watt amp
  1. safgegewgw
  2. gwggwegwgsdgderewgdgweg
  3. cdgegegewgegrgergweweewgewggwewegewg
Dec 13, 2008 | Profile 600MSX Car Audio Amplifier
2001 Audi A6 how to bypass the original amp
The stock amp (mounted inside the sub enclosure) found on the RHS of the boot behind the pull out pannel has a red plug with 8 twisted pairs of wires and 3 other wires (pos, acc and earth).
Out of the twisted pairs you will have
RHS Rear Speaker: Blue/Gray +, Gray/Blue -
LHS Rear Speaker: Red/Gray +, Gray/Red -
You will also have a pair of White/Blue and Brown/White which is the RHS input and a White/Red Brown/White pair for the LHS input. Although... the stock amp uses a common earth input as you will see, the two Brown/White wires going into the same plug.
To put in another amp, you will need one with 'high level' input. Make sure it can take a common ground type input. If it cannot then just use a "high level to RCA" converter.
If you are putting in an after market headunit like i did, then you will just need to separate the two brown/white wires at both ends. If you do this you will need to test which brown/white wire at the head unit end is paired with which wire at the amp end. They are twisted together at the amp end but not at the headunit end (unless you cut the cloth tape back far enough).
Dec 11, 2008 | 2001 Audi A6
Amp
Unfortunately, I can't find the manual for that amp online, so I'm flying blind. If there's anything similar to "system control", that is essentially the same thing as the remote.
Another thing to try is try connecting the +12V wire to one of the "+" inputs at a time. If one of those connections is the remote, hooking +12V up to it but not the other will cause the amp to not turn on. If the amp turns on no matter what "+" input you put +12V on, then we know both "+" inputs are probably are just for +12V.
It's also possible that the DIN plug has the remote as one of the connections in it. Don't know that without the manual.
But, if the amp really, truly has no remote wire connection, you'll need to get a SPST switch or relay to turn the amp on/off. Otherwise, without a switch or remote, your amp would be on 24/7 and drain your battery in no time.
Mar 10, 2008 | Car Audio & Video
Cant get the red led light green again
Disconnect all input and output cables and check. If the light stays red, it suggests an internal error. If not, proceed by first connecting the Sub wires and checking, then the input RCA's and checking. Remember to switch off the system before connecting/disconnecting, I suggest also removing fuses during this process.
Mar 11, 2007 | Pioneer GM-232 Car Audio Amplifier
Audiovox BA200 Car Subwoofer Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
