Question about Kenmore Refrigerators
Kenmore Model 596.77272790 bottom freezer. The ice maker is not working. I suspect that the feed line may be frozen. the ice maker acts like it is trying to come on. no water fills the ice tray. do i need to flush my feed line?
geemarie
  • 876 Answers
SOURCE: ice maker kitchenaid
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Posted on Aug 01, 2008
  • 399 Answers
SOURCE: ice maker stop making ice for kenmore 106.56352500
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Dec 06, 2008
  • 190 Answers
SOURCE: kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Posted on Apr 08, 2009
ginko
  • 19396 Answers
SOURCE: Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
Posted on May 31, 2009
bobicehouse
  • 1524 Answers
SOURCE: The ice maker on my subzero 650 makes ice. But
The water valve is not seating properly due to particles of some kind. Valve is located on the bottom.
Posted on Jun 07, 2009
How can I free up the ejector arm on an ice maker?
Worst case, Remove all frozen items. Turn off freezer or increase temperature to above 32f apply heat with a hair dryer or similar device to the Ice maker particularly near the bottom surface. This should allow you to remove the auger and all ice frozen to the auger. Perhaps less extreme steps can be used to accomplish the auger removal. There may be Ice maker "install" instructions that may make my explanation a little clearer.
May 04, 2015 | Kenmore 26.7 cu. ft. French-Door...
Glide rails on kenmore bottom drawer freezer keep freezing up
I suspect that you've got a leaky ice maker. Do you have clumps of ice in the bin, too? Many times, replacing the ice maker will solve the problem.
Jul 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Model:106.56612500 side by side refrigerator ice maker not working .Possible water valve ,possible ice maker ,possible frozen water line .Ice maker is in the the freezer box not the door What is...
cheapest and up,, check for a frozen water line, defrost the entire unit, any of the components can be iced up, once defrosted,, if you still have a problem, then check the inlet valve ,
Jul 22, 2011 | Kenmore Side by Side Refrigerator
Ice maker will not work. No water flows into ice maker. What is cost of replacing ice maker? Ice maker is part no. 628370.
If the problem is only that you don't have any flow of water in ice maker then you should check the water solenoid, the water filter if its cogged or water container if it is frozen,
In any case the Ice maker is abot $140
Nov 05, 2010 | Kenmore 64802 Top Freezer Refrigerator
Ice Maker is dead on Kenmore Elite TRIO bottom freezer with French doors. This model has separate water dispenser inside fridge on left and ice maker in bottom freezer. We've tried replacing the filter,...
you can check the fill tube in the freezer make sure it is not blocked with frozen water. if you can disconnec the water supply line from the fill tube try and reset the ice maker to advance it to a new cycle and if water come out of the supply line the you knwo there is a blockage if no water comes out the the ice maker may be bad or the fill valve is bad. last thing you may need to call a service tech out to find the problem.good luck i hope that this has helped some what.i would like to knwo how thing go for you
Jan 22, 2010 | Freezers
Remove door and icemaker from bottom freezer model 59673914200 -- icemaker wont turn
The ice maker switch had come unattached due to excess ice buildup, and frozen to the ice pack. The ice in the ice maker had also frozen into a solid block due to not being able to rotate. After removing the drawer trays and protecting the frozen food, turning off the refridgerator, I used a hair drier to melt and remove the ice from the ice maker, gave it time to dry out, -- No gears wer stripped,- the ice maker now works normally.
Aug 23, 2009 | Kenmore Refrigerators
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
177 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
