Question about Weather King 10AJA3601AH Air Conditioner
Need to know how many tons this unit cools - Weather King 10AJA3601AH Air Conditioner
    New Friend:
  • 107 Answers
Judging by the model number it is 3ton.
Posted on Oct 09, 2010
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
No problem trying to find out tonnage i would like to know how big a unit i will need when i replace this
This unit is a 3 ton unit
P3RA-10 SEER
3, 4 and 5 Ton Units
Cooling: 32,500 to 55,700 Btuh
P3RA- Cooling Btuh SEER
036K 32,500 10
048K 45,500 10
060K 55,700 10
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 09, 2011 | Intertherm P3RA-036K Air Conditioner
I have an oddball question. What does a 3-ton A/C unit weigh? I know its not 3 tons.
Not every 3-ton unit weighs exactly the same - they differ in weight depending on how they were manufactured. Most 3-ton units weigh around 150 pounds (I would guess) give or take a few pounds.
The "3-ton" refers to the "cooling capacity" of the air conditioner.
It's actually 'slang' for 36,000 Btu.
Note; 12,000 btu equals 1 ton.
Hence a 24,000 Btu unit would be called a "2-ton unit," and a 12,000 Btu unit would be called a 1 ton unit.
Aug 05, 2011 | Heating & Cooling
Morning, I got a external unit SH24BP2X samsung fro air conditionning, and I'ld like to buy an indoor unit. Is anybody can give me ref which match with this unit. I need 5/6 kw heating power. Thanks...
The 24 in your model number means 24,000 btus. There is 12 thousand btus in a ton of cooling. This makes your unit a two ton. You can buy a air handler sent up for two tons of cooling and then buy what every electric heat pack that you need. let me know. wally
Mar 16, 2011 | Samsung Heating & Cooling
Need to know how many tons this AC unit is
To find out the tonnage, I would need to see the model number. If you can go to the out door unit and write down the number or look for this in the numbers and letters. There are 12,000 btu's per ton of cooling. I don't know if you have a central unit or a window unit, but look for numbers like this. 018, is a 11/2 ton, 024 a 2 ton, 030 a 21/2 ton, 036 a 3 ton, 042 a 31/2 ton, 048, a 4 ton, they don't make a 41/2 ton, and it go's to 060 a 5 ton. This is the largest for a residential that is made. From there they make units for commercial buildings that start at 71/2 tons up to 350 ton's on 10,000' warehouses for wine storage and so on. This is larger then a train box car. You may want to write this down and keep it as most people have no idea how to tell, and now you do. Please don't forget to rate me as I know you will be kind. Let me know if you need my help for any thing.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Sep 08, 2010 | Heating & Cooling
Does not seem to be sufficient cool for a 1600 sq ft manufactured home coming from the Coleman unit installed. Some vents more air, others less air. Unit runs without stopping ever. Can you give us some...
Hi John, depending on the size, I would need the model number from the outdoor unit if it is a split system, you should have 400 cfm per ton of cooling. If you have a 1600 SQ' home, and a 3 ton unit, 3 x 400 cfm is 1200. It would be to small. There are 12,000 B. T. U.'s of cooling per ton. 2 tons would be 24,000 b t u's. 3 tons would be 36, 000 b.t.u.'s. Also, most contractors put lever dampers in the duct work that can be adjusted. They will put a red flag where the lever is and we can adjust the flow to balance out the house. I don't know where your ducts are, under or above, but with a good light find the crawl space and check it out. Get the model number and call it in to get the tonnage or send it to me and I will tell you. It will have a 024, 030, 036, 042, or, 060 in the number, MODEL number and figure like I told you above, 12,000 per ton. 060 would be a 5 ton. This will let you know if the unit is the right size or not. Please rate me on this and I know you will be kind. Thank you John.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
PS CFM is cubic feet per Minute.
Aug 05, 2010 | Coleman Heating & Cooling
DO NOT HAVE BTU LISTED ON AIRCONDITIONER FOR SERIES LP 109755 319Y SERVICE# M6X08F2A-B
Hi, I am not sure what you are wanting to know? If you want to know the size of the a/c tonnage wise, its 5,000 b t u's short of being a 1 ton unit. There is 12,000 b t u's of cooling per each ton. 2 tons would be 24,000 b t u's, 30, a 2 1/2 ton unit and so on. If this is not what you needed to know, please get back to me and let me know. Sincerely,
Shastalaker7
Jul 03, 2010 | Maytag Chassis Built-In Air Conditioner...
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
My weatherking outside compressor isn't big enough to handle my cooling needs. It is 1.5 ton unit, can I put a bigger ac unit onto this one without changing my heating system which is sufficient?
if your indoor unit is 1.5 ton the answer is no
if your indoor unit is 2.0 ton then you can jump to that size.
Note :your duct system may have been designed for a 1.5 ton and may need to be reconfigured for a size increase.
Your hvac contractor should know this?
Jun 14, 2010 | Weather King 10AJA4201AH Air Conditioner
Need help on tonnage question
I would have an air conditioning contractor do a heat load calculation and give you and estimate. 3 ton may work if your insulation is good and your windows seal well. 4 ton may be too much and you won't get the humidity removal needed in Florida.
Mar 04, 2010 | Heating & Cooling
Weather King 10AJA3601AH Air Conditioner Logo
23 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
