Question about Dryers
Dryer won't start when start button is pressed
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 09, 2010
Samsung dryer DV42h5000ew won't power up
Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 02, 2017 | Samsung Dryers
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
DRYER WON'T START WHEN START BUTTON IS PRESSED.
The fuse is located on the heater element which is bolted to the back wall behind the drum.
I have several home movies and repair pix on my DIY blogpage:
PAW PAWs DIY GE HOTPOINT DRYER Repair page
Dec 02, 2012 | GE DVLR223 Dryers
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Does not respond to button press and won"t turn
heatman101
Aug 31, 2011 | Kenmore Elite HE4 Electric Dryer
Unit won't start when start button is pressed.
507
is the thermal limit if open due to lint or other problems the dryer will not run.
Of course it could very well be a broken door switch.
I recently worked on a Hotpoint dryer that was eating up clothing.
I took some photos. Hotpoint dryer revamp
Aug 17, 2011 | GE DVLR223 Dryers
Lights up press start button won't start
heatman101
Jul 06, 2011 | Dryers
My Maytag Performa Model # PYE4500AYW has quit. I press the start button and it won't start.
heatman101
Jun 27, 2011 | Maytag Dryers
My dryer won,t start. When you set the timer and turned the starter on you hear a sound that seems it will run but when you let go the starter it just won/t run
You have a bad motor. There should be a button you can press to make your dryer go while the door is open. Hold that and push the button in and then turn the drum. if that doesn't make it go then it is your motor
Apr 18, 2011 | Frigidaire Dryers
Dryers Logo
49 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
