Question about Acer Aspire 3000 Notebook
High temperature CPU!
Hi!
When i work something at 2G speed the temperature increase very much and the laptop shut down!
  • Anonymous May 31, 2008
    my acer 3003 always seems hot.. the fan stays on a lot..and if im watching a movie, it will shut down on me, any ideas? Steve in Ontario.
Take the bottom off the fan compartment and clean and blow out any dust, it can get very clogged. I have the same machine for many years. During a DVD movie the fan will switch on and off a few times. Also check the CPU useage, during idle it should be very low. Its possible a rouge program is demanding high CPU
Posted on Jun 12, 2008
I study rhe simptom in all this time , and i think the heatpipe system is overloaded, i think need more heatpipe.
drummer_67
Posted on Jun 01, 2008
    Sergeant:
  • 458 Answers
NEVER not use your laptop on a flat surface. Buy something to prop it up with. Then get a small fan and sit it by the laptop. This should help. This laptop breathes from the bottom.
Posted on May 31, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Can you please let me know if this solved your problem?
    Rate this as a fixya if your problem is solved please.
    If you need more help let me know.
    You can buy a stand with a built in fan also.
Cpu temperature when Power supply is connected (notebook HP Probook 5330m)
It almost look like your power supply output voltage is too high as if it lost it's regulation. Have you got any multimeter you can measure this with? Or do you know someone who has the same model HP who could loan you his power supply for a test? Let me know the results.
Mar 08, 2014 | Speed Pc Cpu Vga Hdd Fan Control...
I did everything (remove,check,clean,replace thermal past) for my qosmio F30-140's fans, but still they run normally without temperature level. Despite of high temperature, they run normally; before it...
Not sure if I understood the problem, but fan's speed is controlled by a motherboard. if it's intel CPU based laptop, usually the temperature might reach 80 C degrees before fans start to spin faster.
Oct 30, 2013 | Computers & Internet
Computer idles high then shuts down
When you say "idles high" do you mean you hear fans spinning faster or louder? If so, a fan spinning at higher than normal speeds is indicative of components/chips being run aggressively causing them to run at much higher temperatures. You may want to look into getting temperature monitoring software like CPU-Z to monitor the temperatures of your CPU and GPU. These components are the most common ones to be running at high temperatures. If any fan has failed on them the secondary fans (if there is one) will run at much higher speeds to compensate. Your PC may have a safety precaution to automatically shut down if certain temperatures are reached to prevent permanent damage to the components. Are you getting any blue screens before it shuts down?
Oct 16, 2013 | E-Machines eMachines Desktop PC
TOO HIGH TEMPERATURES AT MY LAPTOP ACER ASPIRE 5735Z
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Aug 01, 2012 | Acer Aspire Computers & Internet
Can i adjust the fan speed in the bios on my hp zd8000
You don't have to reduce the FAN speed, because the Fan power works in PWM (Pulse Width Modulation). I.E if the CPU processing is increasing due to high process load, the fan speed changes accordingly to maintain a CPU normal temperature.
May 22, 2011 | HP Pavilion zd8000 Notebook
Fan speed does not increase while cpu temperature is far too high
Hello
The fan speed is automatic, when it need to increase it will done by itself, if fan is OK then there is no need to worry. Good Luck
Feb 15, 2011 | Compaq Presario 700 470024-192 Notebook
Random shutdown problem
Hey, will be cpu related ie overheating, when your playing games causes the cpu temperature to increase once it hits around 60c it will restart to save damage to your laptop, i would suggest making sure the fan is working if not have it replaced, but depending on ya knowledge i would suggest taking it to a shop to repaste cpu and clean out heatsink etc.
May 11, 2010 | HP Presario C700T Notebook
Laptop shut downon its own
Your fan has failed! Your cooler not working properly, clean your cpu-fan. Your CPU is over-loading temperature is too high without an working fan! This is your Problem!
Sep 03, 2009 | Lenovo 3000 C200 Notebook
Aspire 5610-4621
hmmm..sounds like a thermal issue....do you, by chance have it sitting flat on a hard table? You know, it's most effective to have a laptop, UP off the table, on one of those 'risers' that are available in most electronics or computer departments. Not unlike a trivet for sitting hot pots or pans on.
got backup for that Acer?
Feb 20, 2008 | Acer Aspire 5610-4648 Notebook
Main cpu fan high speed
the speed of the cpu fan will go up and down depending on the work load that your pc is going thru,lets say you start a game and the speed increases then drops down thats all normal
Oct 06, 2007 | ASUS 865G (MBAS-P4P800VM) Motherboard
Acer Aspire 3000 Notebook Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
