Question about Kenmore Oasis HE 27082 Top Load Washer
No matter what I do it cannot balance the load to complete the spin cycle. What Can I do to fix myself?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
This is actually a Whirlpool Cabrio with a Kenmore sticker on it. What I see alot on these is one of the struts will go bad and it will have an effect on all of them. Buy a strut set and install. It's easy.
Rich
Western Appliance Repair
Kenmore Repair Boise
Posted on Oct 09, 2010
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Constant out of balance on washer
Check the inter tub ring you should hear water when you spin it by hand
if you dont hear water replace the spin tub balnce ring it must be cracked or has a hole in it and leaked out the fluid this is a counter balancer when it gows into the spin cycle
h Tech AL Wojo
Apr 01, 2013 | Maytag Bravos MTW6600T Top Load Washer
Intermittent no spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
My washer will not empty all of the water out on the spin cycle, it does not matter which wash cycle I have put it on. I have even tried the Drain and Spin cycle. I have even taken all of the clothes out...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Jul 15, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirpool Washer, Loads become unbalaced in spin cycle.
it has a bad balance ring on the top of the basket no so hard but not that easy either
you have to remove the case to get to the balance ring
go to www.sears.com and go to parts and put in the full model number, under the parts tab in appliances and select view brakedown and it will explain it better with you seeing it
May 08, 2008 | Whirlpool LSR5132PQ Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
73 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
