Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
1 min remaining time takes 30 mins
I have a front load HE3. Once the timer reaches 1 min, it actually takes 20-30 min before the cycle finishes. Does anyone know why???
  • Anonymous Jun 03, 2008
    This crazy machine.....I thought the hose was plugged for draining,but no.
    The codes I get are F02-drain problems, F09...???? I need help.
    Novelist:
    Champion:
  • 261 Answers
The timer given a approximation of time left and because of balance the machine is fluffing the clothes to achieve a balance.
And for the guest it looks like you have junk in the pump. Need to access the panel below the door by removing the screws and getting a bucket, removing the large screw to the left of the pump and checking for debris in the filter, in the boot,behind the pump and look in the hole when the filter is out for damaged impeller or coins.
Posted on Sep 15, 2008
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Kenmore HE3 2plus wont finish cycle
I'm not saying you don't have a problem. But just to be clear. You do understand that the last minutes on these machines can vary. The machine senses certain conditions in clothing, water discharge, etc. So sometimes the "1 min left" indication can stretch into many minutes. In theory, at least, it's possible your machine just needs to be left alone until it finishes whatever it's doing. However, one would think that any issues not resolved in 10 - 20 min are an indication of a problem. So i guess that's my next question, did you wait long enough? Keep in mind i am not a kenmore expert.
Jan 06, 2013 | Kenmore HE2 Plus Front Load Washer
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
Have a small Kenmore freezer (31" high x 24" deep by 21" wide). It works fine as far as freezing, but it never cycles off. Just keeps on going and going, driving me crazy. I also continually hear a subdued...
the wooshing maybe the oil/freon migrating thru out the internal system...
The cycle depends on 2 things... t'stat operation and timer. The timer usually shuts off freezer every 6 or 8 hrs for 20 to 30 mins. But the t'stat (once it reaches desired temp. should shut off freezer every 15- 20 mins. for an average 10 -15. So 15 mins off min 15 mins on (that is if the doors is not open) you get my point something like that...
but the way you describe to me it sounds like the t'stat. set it at 1 if it dont shut off and you are absoultely sure you got zero degrees (use a temp. reader) then replace the t'stat
hope this was helpful
let me know if this didnt work then plan B
Mar 09, 2010 | Freezers
When the timer gets down to 1 minute left and the machine is on the spin cycle, it takes another 10-20 minutes to finish the cycle. The total 40 min. cycle takes over an hour to complete. Does anyone know...
The timer is only an estimate. pull the botttom cover of the front of the machine. There is a cleanout on the water pump, if its clogged it could be the cause of your timer taking so long
Jun 11, 2009 | Whirlpool GHW9100L Front Load Washer
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Time remaining stays at 1 min for 20 min
This may happen if using the Super-eco program.
It is designed to extend the washing time / cycle, but is less intesive in rotations. It's more a long gentle soak than a quick scrubbing action.
Thank you for using Fixya! If this provided a solution, please rate as such. Thanks.
Jan 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Long wash times
I've had this problem, particularly with towels - it's quite annoying & not energy or water efficient at all. According to the manual, the unit has a sensor that senses if there is too much soap & it will continue to wash until the soap is removed. I found that this happened frequently on the "cotton" cycles & max spin. I've tried to make sure I use less soap, but I also use the perm-a-press cycle & the spin 1 down from max. Hope this helps
Sep 07, 2007 | Bosch WFMC 3200 Front Load Washer
Ge front load-
We had the same scenario, only our clothes were still very wet when it finally finished the cycle. To cure all three we cleaned the filter behind the front panel. It was badly plugged and it, and the water it was holding up, smelled foul. So far so good since.
Aug 16, 2007 | GE Energy Star WCVH6260F Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
201 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
