Question about Refrigerators
I left the door open on my freezer yesterday and today everything was thawing and the freezer was off. As I was cleaning it out, it came back on,but it's very hot. What should I do?
    Sergeant:
    Champion:
  • 351 Answers
Hi leave it on it was in defrost should start cooling jim
Posted on Oct 10, 2010
The freezer door wasn't closed properly overnight 2 nights ago and it still didn't cool properly after the whole day yesterday and today. There was a noise which I didn't recognize but now in retrospect...
Is RS261MDWP the correct model number? If you left the freezer door open there is an excess amount of frost covering the evaporators because moisture was drawn inside and has frozen on the evaporator and is too much for a normal defrost to get all of the ice off and drain into the pan below the refrigerator. It may have also frozen over the condensate drain and not allowing the water to drain. You may need to clean the drain hole and defrost the refrigerator manually and insure the evaporators are clear of backed up water. If you don't there is a chance the refrigerator will continue like this until you do. Let me know what the status is so I can help.....Sea Breeze
Does your model have two evaporators?
Aug 05, 2013 | Samsung / RS261MDWP
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
GE fridge and freezer cools when it wants to - freezer on top
hard to say, there is many questions left that need answered...does the compressor run, does the fans run? what more could you tell me.... whirlpoolpartssurplus.com free tech support
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our freezer has been running nonstop to refreeze everything and now it is blowing warm air. What do we do? Unplug for a break or just shut the door?
Have u checked the thermostat setting? Set it as u usually do and if indeed the door was left open, then try shutting it down for(unplug) 10-12 Hrs and see if behaves normally after wards(set the thermostat too).
If not then have the thermostat replaced.....sodeep
Jun 02, 2009 | Maytag MZD2766GES Side by Side...
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
