Question about ViewSonic PJ501 Multimedia Projector
Unit will not power on
Just received my projector; loaded software, registered, connected VGA cable to unit, then to laptop; connected power cord to unit, then to laptop; power light flashing yellow, held for 2 seconds, flashed green for several seconds then back to yellow. The lamp never came on. Unit makes "whirring" sound as power light goes from flashing yellow to flashing green, but lamp never comes on. I desconnected and reconnected twice since last night, and the same thing happens. I have used a borrowed Infocus unit just recently, so I know it is not my laptop. Please let me know what else I can try before I return this unit.
  • tomakazy622 Dec 17, 2008
    th greem power light flashes on and off,then after a while the power and lamp lights turn red. the lamp light will not turn on
Company said it was defective. Sent back for exchange.
Posted on May 31, 2008
My dell xps 1210 laptop wont show image on viewsonic pj588d projector. it works on another laptop but not on xps 1210
Try F1 or Fn and F1 or connect up the projector, power up the projector select VGA input (or whichever input is connected to the laptop) power on the laptop.
Dec 27, 2014 | Dell XPS Computers & Internet
I am trying to hook my notevision projector to my laptop so that i can show a powerpoint. I did not receive a cord with my projector. Which cords will i need? I received a usb to usb and VGA cord but i...
I tend to use the VGA cable. Once connected, switch the laptop on until you get to the desktop, then switch on the projector. Some will see the signal, if not, simoultaneously press your FN and relevant 'F' key to send the signal out to the VGA. You may need to do this 3 times, once to send to projector, one to send back to laptop screen and then once to send the signal to both projector and laptop screen. Sometimes this can take a short amount of time. You may want to change the projector settings to the VGA input so it doesn't constantly search for a source. If you still have problems, go into properties on your laptop and advanced. you m,ay need to unclick the box saying 'Extend to..........' (You should find what I mean from this, I am in front of a pc therefore the settings are slightly different.)
If nothing then works, it may be your video card.
Good luck
Aug 11, 2011 | Sharp Notevision PG-M20X Multimedia...
I can't get marry my laptop to the projector the manual is lost. had to buy new usb cord and still can't get the projector to play my video
the projector needs a vga cable or composite connection to show the display from the laptop , it will not work with a usb lead
If you found this info useful please vote for me
vga to vga lead looks like this
a composite lead looks like this
Mar 30, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
We have connected both the cables (VGA and HDMI) in the Vivitek D945VX but when we use just one cable VGA or HDMI at a time to display through Laptop, the projector would not display properly (sometime it...
you are using a long cord but this should not effect it.... try unplugging the cable you are not using from the projector and just have the one cable going from laptop straight to the projector... hope this was useful...
Feb 26, 2011 | Vivitek D945VX Projector
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
How do I connect to my projector
If your dell is equipped to do this it is on the back side and appears as a video card connector or s-Video out. It is possible that your Dell is not equipped to make this connection, I have found a few that are not.
Oct 12, 2009 | Dell Inspiron 1300 Notebook
Connecting Dell laptop to Infocus LP820
The USB cable doesn't transmit Video. You need to plug in the VGA cable. The "DVI" port on the LP820 is not a a DVI but a M1 Digital port and won't work with DVI unless you get a converter.
Nov 30, 2008 | InFocus LP 820 Multimedia Projector
Connecting Macbook with a compaq MP1400 digital projector
You're going to need a conversion dongle that goes from the Mini-DVI to VGA.
  1. Connect one end of the projector signal cable to the Video Graphics Array (VGA) connector on the projector.
  2. Connect the other end of the projector signal cable to the Digital Video Interface (DVI) connector or VGA connector on the notebook computer and tighten the screws.
  3. Connect the projector power cord to the power cord connector on the projector.
  4. Connect the other end of the power cord to an electrical outlet that is easily accessible and close to the projector.
  5. Turn on the projector first, then turn on the computer.
Nov 09, 2008 | Computers & Internet
ViewSonic PJ501 Multimedia Projector Logo
252 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
