Question about GE WJSR4160DWW Top Load Washer
MY GE WASHER MODEL GJXRP080 IS NOT DRAINING/PUMPING OUT THE WATER. I STRNGLY SUSPECT THAT THERE IS A BLOKAGE. PLEASE EXPLAIN STEP BY STEP PROCEDURE TO SOLVE THE PROBLEM.
My 7-year GE washer (can't locate the model #) won't stop turning & running water, what could be the problem? Thank you
Posted on Nov 06, 2010
My Ge Eterna washer will not drain the water but will spin on spin cycle
You got no clear question here. Does the spin cycle pumping out water or not. If it is spinning but water was not pumping out so the issue is from the pump. It is either blogged or out of order.
Oct 15, 2013 | GE Profile WPRE6100G Top Load Washer
Washer stopped pumping water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 28, 2011 | GE Energy Star WCVH6260F Front Load Washer
Water not pumping out
heatman101
Oct 10, 2010 | GE WBSR3140DW Top Load Washer
Front load GE Adora washer isn't spinning when it should. Other sites I see they talk about replacing the door lock assembly...what else could it be?
I had the same problem with my front load (different model). The pump was not pumping out the water, thus stopping or slowing the spin. Take off your pump (located under the washer in the front right on my model) and look inside to see if there is any junk stopping the plastic spinner to spin. Clean out really good along with the attached hoses. Replace (tricky!) and try the washer! I had lots of junk in the pump along with a few hairpins that stopped the sinner in the pump. This is a tricky process on my model.
Mar 28, 2010 | GE WSXH208A Front Load Washer
Water not coming out of machine
If water is in machine and not pumping out there could be a blockage in the outlet pipe or pump. If you can not hear the humm of the pump then there may be a pump fault. Possibly just a blokage in the outlet pipe though.
Feb 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Washer not draining/pumping out water
There is an instruction sheet in the control console. It will explain how to open the washer.Once inside the washer, clean the pump hose and the inside of the pump. It will be on the bottom right hand side.You will have to disassemble the pump to clean it.
Apr 08, 2009 | GE WDSR2080D Top Load Washer
Need to get water out of washer SPIN CYCLE DOESN'T START PLEASE HELP
If this is a Whirlpool, Estate, Roper, or Kenmore model Top Loader, the problem is a lid switch malfunction. This is the most common symptom when the lid switch fails. The washer will either fill normally, then stop. Or, it will fill, agitate, then when it gets to the spin cycle, it will stop. If these match the symptoms you are experiencing, please post back and let me know. I can assist you and explain how to repair this problem. This is an inexpensive repair that anyone can accomplish with a little guidance. I have step-by-step instructions posted under the "Tips and Tricks" section of my profile.
Please provide as much information as possible when posting questions, as all washers are not alike and symptoms differ between models. This makes it much easier for us to provide you with the proper diagnosis. Let me know if you need my assistance.
PS You do not need to drain the wash tub to repalce a defective lid switch. The washer will drain on its own if the switch is replaced. In the interim, I can also give you advice on how to by-pass the lid switch as a temporary means of draining the washer.
Sep 15, 2008 | Washing Machines
Spin and Agitate problem on GE Profile Prodigy WPSE4200A
This machine uses an electric water pump. I would check to motor. Remove the front panel and operate the machine to see if the motor is working. Check this by listening to the motor and watching the belt. If you hear the motor but the belt does'nt move then there may be a problem with the pulley or motor clutch assy.
As far as not draining or pumping water ? Check the wiring from the pump to the control panel. If these wires are alright then i suspect the pump.
Nov 15, 2007 | GE Profile Prodigy WPSE4200A
GE WJSR4160DWW Top Load Washer Logo
196 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
