Question about Panasonic PT-47WX53 47" Rear Projection HDTV
The "red" in the picture is distorted... Not lined up with the other colors on the screen... It looks like it is bent
    Problem Solver:
  • 10 Answers
Shlapperpau, agree with Slinteriors that you need to replace the convergence chips. Not sure you need to spend that much on a "kit" that includes about $10-$20 in parts, but depending on your comfort level it may not be a bad solution.
I have a different and more technical question, that a link to a website won't fix. Let's see if there is anyone out there that can answer this one. :)
I own a Panasonic PT-47WX53 "AND" PT-53WX53.
Ok, will try to be as detailed as I can with this question, I REALLY hope someone can guide me through this. I have been reading posts for 2 days, and only one other person seemed to have this issue, and no one responded to his post. :(
I have 2 Panasonic TV's, the 47" and 53" of the exact same model.
It just so happens they seem to have the EXACT same Video and Power boards in them. Honestly the only thing I can find that is different is the size of the cabinet and screen.
Well, they BOTH had the convergence problem that sounds like 80% of the people have that posted. So I ordered (4) of the stk-392-110. Replaced them on both boards.
Results: The 47" TV is working fine now, came right up. Unfortunately there is screen burn in and not my favorite set. The 53" is cutting off with the 3 blink, (Convergence problem still). I will get to this board later and manually test each resistor, but for now, I want to use the 47" board in the 53" case.
Problem: The TV comes up fine with the working 47" board installed in the 53" cabinet, HOWEVER the picture is "skewing" like a convergence issue, but that is all fine. I believe it's just some setting in the board that needs to "Stretch" or be factory set to tell it that it is in a 53" cabinet instead of a 47" where it looks perfect within the 47" boundaries.
I have the service manual, and get into the settings, but I am not sure exactly what I need to change. Service Manual doesn't explain in detail what all of the settings do (please don't post if you're just going to spout about how only techs should be in the service menu. I understand and take on the risk, and tired of the wasted posts of such).
1. Honestly I would like some confirmation that this should be able to work (47 board in 53 cabinet), before I start making these changes, find out it doesn't quite sync up for some reason, and then have to put it back in the 47" and start over.
2. Is there a way to "reset to factory" in service menu? Can't find anything in manual.
3. I have not made any manual changes to the tubes inside the back of the case. Could this be the solution? I know the R,G,B tubes can move for focus, but would I need to move them to stretch out the image to the corners of the screen?
Hopefully this makes sense and gives someone on these pages more of a challenge than the normal "replace your stk-392-110's and resistors" :)
Any help is much appreciated, will be working on finding the problem on the other board in the meantime, but someone had already worked on it, and probably messed more up on the board.
Posted on Oct 29, 2010
  • Brian Wilson
    Brian Wilson Oct 29, 2010
    Not impressed with Fixya's abilities to post questions, or edit responses..
    Above post meant to say "Panasonic PT-47WX42F "AND" PT-53WX42F"
  • Panasonic Master
  • 8,617 Answers
The convergence needs replacement. You can get the panasonic PT53WX53 convergence repair kit from www.tvrepairworld.com which is correct for your model. The kit contains the parts and the CD with instructions
Posted on Oct 09, 2010
The picture is distorted as well as the color
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 20, 2010 | Panasonic PT-51HX42 51" Rear Projection...
I have some distored blue color across the screen
*Screen Looks 3-D
*Colors wont align
May 15, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Hi my problem is I have red lines across the screen with double picture
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 19, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Problem with Sony KP46WT500: Each line on the
Symptoms:
  • Colors wont align
Mar 16, 2010 | Sony KP-46WT500 46" Rear Projection...
Objects are doubled and colors are distorted
*Screen Looks 3-D
*Colors wont align
Jan 11, 2010 | RCA R52WM24 52" HDTV Projection Television
Seeing red, blue,geen wavy lines across screen which distorts picture while viewing.
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Jan 02, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Red, Green convergence lines are wavy
*Screen Looks 3-D
*Colors wont align
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
PICTURE IS FUZZY AND DISTORTED
*Screen Looks 3-D
*Colors wont align
May 26, 2009 | RCA HD52W59 HDTV Projection Television
Convergence problem
my convergence are having a problem the blue color won't moved
Oct 03, 2008 | Toshiba 50H82 50" Rear Projection...
Picture Problems: Snow, color, lines
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 23, 2008 | Sony KP-53XBR200 53" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
112 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
