I Need Magnification I have low vision - Computers & Internet
    Scholar:
  • 110 Answers
You need the magnifier from the Accessibility tools. On Windows XP this can be found in Start Menu -> Accessories -> Accessibility -> Magnifier (if it's not installed, go to Control panel -> Add/remove -> Add Windows Components and install it)
On Windows Vista it's in All Programs -> Accessories -> Ease of Access -> Magnifier.
Posted on May 30, 2008
How and where do i remove the battery
Note where he points to place the battery at 3:49 minute mark
Night Owl Optics Night Vision
requires (1) 3-volt Type-123 lithium battery (not Included)
Apr 15, 2016 | Night Owl Optics Night Owl NONEXGEN-W...
At what magnification is the focus ring distances correct on a Nikko Stirling NSTT52050MD
None of them as it is to low a magnification to get a precise range from
the only way to check is to measure out distances to targets at the ranges on the side wheel and decide
Dec 03, 2012 | Nikko Optics
What do the terms 3x40 mean
The first number specifies the magnification. The second number is the size of the front lens. "3x40" means a three-power magnification with a front lens 40mm across.
The lens size is given because a larger lens collects more light and thus produces a brighter image. A 7x50 will be usable longer after sunset than a 7x35, for example, though neither should be considered as night-vision glasses.
Nov 13, 2012 | Leapers Accushot 3X40 Cqb Retical...
How do I increase the field of view on a zeiss OpMi-1?
Field of view and working distance vs magnification is a law of physics. Using the lowest power gives you the widest field of view and greatest working distance but the trade of is that you loose magnification. Conversely as you increase magnification you decrease working distance and you loose field of view diameter.
The optics of your microscope are limited to .4x to 2.5x magnification. Your working distance is limited to 200 - 400mm depending on the magnification you are using.
I am not aware of any interchangeable lenses for this scope.
Nov 28, 2010 | Zeiss Microscope
What is low vision?
Low vision is a term describing a level of vision below normal (20/70 or worse) that cannot be corrected with conventional glasses. Low vision is not the same as blindness. People with low vision can use their sight. However, low vision may interfere with the performance of daily activities, such as reading or driving.
Nov 23, 2010 | Health & Beauty
How to determine the lowest possible usable magnification for a telescope
Don't confuse low power with WIDE field. Usually to get the lowest power and widest field you need to move to a 2 inch eyepiece, and a 2 inch diagonal.
About 38-42mm eyepiece will be the lowest power. Take a look at the GSO Superview 2 inch eyepieces, which yield a wider view. and low power.
Oct 29, 2010 | Celestron CPC 925 XLT (555 x 235mm)...
Is my bushnell insta vision 7x35 or 10x50- how do I tell ?
The first number is the magnification the second number is the size in millimeters of the objective (large lens) So if you measure the diameter of the front large lens that will give you the size. So a 10x50 means a magnifyng power of 10 and an objective of 50mm.
Now to find out the magnification if you don't know what it is. Measure the front lens. Then if you look through the eyepiece lens while holding it away from you you will see that there is in each a small circle of light. That it what is known as the exit pupil. It lines up with the pupil of your eyes when you have the binoculars pressed up against your eyes. Now measure the diameter of the exit pupil in millimeters. It will only be a small number.
To work out the magnification use this formula. Magnification = Objective size divided by the exit pupil.
So a 10x50 will look like this M = 50 divided by 5....therefore M =10 which is the magnification.
Both the 7x35 and 10x50 will have an exit pupil of 5mm. So if yours is one of these then all you need is the objective (large) lens size.
Aug 04, 2009 | Bushnell InstaVision Binocular Binocular
Does this telescope need accesories for proper function
Do you have eyepieces? At least two? The bigger the number on the eyepiece the LOWER the magnification-- something around say-- 20mm and 10mm ??
Usually their is a small "finder" scope attached to the top of the main tube to use to help you center and find distant objects. ??
and of course a tripod to hold the telescope.
Look through this web site--
http://www.agenaastro.com/
Apr 14, 2009 | Vivitar Optics
Problems with viewing under low magnification (20x) only red stain
hello..
For the red colour partical your illumination angle should be 0 degree.
As per you exepirience you are getting red at low magnification and not getting at high magnification. at the higer magnification the light deviation you can apriciate more then lower.
try to adjust your light source focusing lenc at higher magnification so at the lower it will be more better,
for the further problem you can contect me any time,
regards.
INDRAVIJAY
Oct 11, 2007 | Tasco 750 Monocular Microscope
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
