Question about Slant Fin Heating & Cooling
Pilot lights main burners light when reach temp mains turn off pilot stays on but low then goes out. put new heat thermocouple in.
  • Slant Fin Master
  • 43,501 Answers
Check the pilot flame as the burners are running and just after the mains shut down... often times when the mains run the extra draft pulls the pilot flame away from the thermocouple...
You may have to readjust how the themocouple is in relationship to the pilot flame...also I have had the cover for the pilot flame bend back as the metal heats and colls many times...you may have to bend the cover back in place to redirect the pilot flame onto the thermocouple...
Of course also the pilot flame may have to be turned up a bit by using the screw under the cap on the gas valve right where the pilot tubing goes out of the gas valve...
Check the connection at the thermocouple and the gas valve to make sure it is seated correctly...
If al else fails the gas valve may need to be replaced, but this is very rare...
heatman101
Posted on Oct 09, 2010
Richmond gas hot water heater. After I light pilot and main burner why does it flame out in 15 seconds?
If you had to light the main burner manually, something is wrong. Once you light the pilot and it stays lit, the flame heats the thermocouple to open the gas valve and fire the main burner. Either or both of the components you replaced could be defective.
Sep 10, 2015 | Water Water Heaters
The pilot goes out when the heater cycles
The thermocouple is not working correctly. sometimes you can clean the soot build up from it and it will work again. sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 18, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
The pilot will not stay lit after water in tank reaches desired temperature. After tank cools down pilot will relight and heat water again thyen goes out approximately 1-2 minute3s after water has been...
Thermocouple is getting weak... the extra heat from the main burner will keep it lit but after it goes out the thermocouple will then shut down..
Replace the thermocouple...
heatman101
Apr 30, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light goes out when gas turned on
I am assuming that you are saying that after you have pushed the pilot knob down and the pilot lites and stay lite and then you turn the knob to turn it to ON the pilot goes out...... Then the Gas Valve is bad and will have to be replaced....... Or if you are saying that the pilot goes out when the burners come on then you may need to replace the Thermocouple because the main burner flame is pulling the pilot flame off of the thermocouple and it is weak and will shut the gas off.... Or You could have a cracked heat exchanger that when the burners are on and then the blower comes ON and is blowing the flame around and blowing the pilot flame off of the thernocouple......which will shut the gas off....and then you will need a new furnace or New Heat Exchanger...... These are the most common problems Hope this helps.....
Feb 16, 2011 | Heating & Cooling
I can get the pilot light lit but will not stay on to light the burners
Try cleaning the thermocouple or replace it. The thermocouple senses heat from the pilot light and in turn brings up the gas to the main burners upon request from the thermostat.
Dec 20, 2010 | Rinnai Toyostove Direct Vent Heater:...
My gas furnace pilot light goes out after reaching temp, the blower keeps going and blows out pilot light. then the blower stops. it will light back up after motor stops
The room air blower should have no effect on the pilot unless there is a crack in the heat exchanger. Do you notice a change in the pattern of the main burner flame when the blower turns on? If so, you have major issues. If not, it could be a dirty pilot orifice or a weak thermocouple.
Jan 14, 2010 | Heating & Cooling
The pilot light does not stay on so heater won't light.
to thermocouple where the pilot light sits is either dirty/carbon out of alignment flame not burning on it correctly or damaged/broken which would mean replacement
Oct 19, 2009 | Uniflame Patio Heaters Stainless Steel...
The pilot light on my gas water heater continually goes out. I can re-light the pilot and get it going. The gas burners goes on runs for awhile. I'm assuming when that when the temp hits the desired temp...
getimage_new.asp?id=599586&imagetype=2&noimagetype=2&colorimagesize=2
The pilot assembly should look similar to the pic above. Depending on where you live, you may be required to hire a certified plumber to replace the parts. If not you can do it your self. Keep in mind if it's not staying lit you also need to check the thermostat and the thermocoupler before replacing the pilot assembly. There is a good chance it is just the thermocoupler going out. It is one of the first things to check when troubleshooting a pilot light problem with a gas water heater. A thermocouple determines if the pilot light is lit. If it's not lit, the gas valve fails. If that's the problem, replace the thermocouple.
  1. Shut off the gas valve on the water heater and the gas valve on the line near the heater. Remove outer and inner doors, and loosen the pilot and supply tubes and the thermocouple connections to remove the burner assembly.
  2. Step 2 Loosen the screw holding the thermocouple to the bracket. Remove old thermocouple. Bring it with you to the store to ensure you are buying the proper replacement.
  3. Step 3 Install the new thermocouple. Position the thermocouple so that the pilot flame heats 1/2 inch of the tip.
  4. Step 4 Reinstall burner assembly in the water heater. Tighten burner supply tube, pilot tube and thermocouple connections. Tighten thermocouple no more than a quarter turn more than hand-tight.
  5. Step 5 Turn on both gas valves. Check supply tube and pilot tube for leaks with soapy water. If soap bubbles, tighten connections to fix leak. Ignite the pilot light, and make sure the thermocouple tip is heating up. Replace inner and outer doors.
Jul 09, 2009 | Northern Tool Water Heaters
Heating & Cooling Logo
Top Slant Fin Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Slant Fin Heating and Cooling Expert? Answer questions, earn points and help others
