Question about Refrigerators
Why is my refrigerator is pooling water at the bottom underneath the 2 crisper baskets?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
If it's a top mount, freezer on top, then this means your defrost drain is clogged. A quick fix is to let the fridge dethaw. A more permanent fix is to remove back panel on the inside of the freezer, defrost, hang copper wire from the heater element into the hole. This will prevent a re occurance.
If you have a duel evaporator, evaporator inside the fridge, then drain hole is probably clogged there as well.
Rich
Western Appliance Repair
Appliance Repair Boise
Posted on Oct 09, 2010
Samsung refrigerator
The moisture has to be getting inside to pool. Check your door seals or leaving the doors open to long.
Aug 14, 2016 | Samsung RF265AA Bottom Freezer French Door...
Why is water pooling under right crisper?
On defrost refrigerators water is drained down the sides to an outlet on the bottom of the interior of the unit and then to a tray under the unit, close to the floor, where it is heated and evaporates.
If he hole inside is plugged then the water will pool inside.
Take out both crispers and try to find the location where the water will flow out. It may be plugged with gunk The inside bottom of the unit may have indented runs where the water will be directed to the outlet.
Oct 27, 2011 | Samsung RF217ABWP (20 cu ft) Bottom...
Danby Designer All Fridge (no freezer) Model # DFF1776WE Water pooling underneath crisper drawers. Very full every couple of days. Then it leaks out the bottom door hinge. Not sure if drainholes are the...
Yes it is located in the refrigerator on the bottom in the back. I assume you know how to clear it, Hot water plus towel to soak up excess water should take several tries of very hot water until it clears. Good luck
May 26, 2011 | Danby Designer DAR1102W Refrigerator
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
I have a new F&P refrigerator model E450RXFD upright fridge only, I have only just got it last week... I have water pooling on the bottom under the fruit and vegetable crisper part ???? any ideas what...
I have the same problem with my E450RXFD, 1st week i got it and noticed it pools water under the crisper. Not too sure what to do about it.
My parents have the same fridge (only 8 years old and theirs does not pool water)
Dec 26, 2010 | Fisher and Paykel Refrigerators
MTB2656G Top Freezer Refrigerator: Water is leaking and pooling below crispers in ref...
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 06, 2010 | Maytag MTB2656G Top Freezer Refrigerator
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 28, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Refrigerators Logo
495 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
