Question about KitchenAid Kitchen Ranges
I need a wire diagram for a kitchenaid YKESC307HW4, the dual element (LF) switch needs to be replace but forgot which wires came of which terminal on the old switch. The new switch is #8203536 and the terminals are labelled differently. There are instructions but I don't know which wire came from where on the old switch.
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: wiring hookup for a replacement part
hopefull yyou havent disconnect old switch yet. whirpool and kit aid are same Co. same parts used. assuming the correct part was sent for the corrrect burner. diffrerent element will require different rated swties(ie. small , large, dual and so forth.), the indivudal switches are labeled, on the swithc itself ( L1,L2,H1 H2, P1 andso forth, so although the switches looke differnet they should stil have the same lettered terminal to plug into .
Posted on Mar 16, 2008
SOURCE: need wiring solution for replacement part
Ok....Just replaced the Left Front "dual burner" switch on my Kitchenaid Supurba.
Original switch symptom:
Burner was stuck on all the time. We had to switch the circuit off in the main breaker box in the basement.
New switch problem:
The new replacement switch did not work properly. The element would come on and would never cycle on and off. Thus, the net result was if you turn the burner on, it was on "high". It didn't matter where put the heat setting at...It's on high for both the inner element and the larger outer element.
I ended up taking the old switch apart and found that one of the contacts was mis-aligned and wedged itself in the "closed" position. I un-wedged the mis-aligned contact and bent it back into alignment. I took out the new switch and put the old one back in. It works perfectly.
Meanwhile, I had to figure out why the new switch was not working. The new switch comes with re-wiring instructions because it is not an exact replacement as the old switch. There is a chart that tells you what wires go to which prongs on the new switch. The new switch also includes a "jumper wire" that must be installed. Here's where I went wrong. The instructions say to jump S1 to P1 (which I did). But, I did not route it exactly as the picture shows and the brass crimp end actually hits against another unused connector. So be careful when routing the jumper wire.
Old Switch Number: 9751758
New Switch Number: 8203536 (Made by FSP Appliance Care Products - A Whirlpool Corporation)
Now for the wiring:
Description Wire Color Old Switch New Switch
& designation Terminal # Terminal #
L1 Black (RL1) 2 P1
H1 Red 3 4
H2 Orange (LFA) 4 4A
P Dark Red 5 S2
N or L2b Brown (LFN) N 2
N or L2b Red (RL2) N P2
On the new switch, use the supplied jumper wire to jump S1 to P1 as instructed.
Yes, on the old switch, 2 wires connect to a common connector (the Brown LFN & Red RL2).
Unfortunatley, I did not document the red wire (LF3)...Sorry....
Hope this helps.....
Posted on Apr 05, 2009
breddi2
  • 126 Answers
SOURCE: dual element on ceran top will not turn off
Problem should be in the switch that activates either inner or outer burner selection.It is the only source that makes selection possible
Posted on Apr 21, 2009
Agco Allis 1691660, 1316H48, need colored wiring diagram for the neutral switch,
if there are only 2 wires it will not matter which wire goes to which terminal
micro switches are simple make or break units and are not directional sensitive
May 31, 2016 | Garden
I HAVE A WHIRLPOOL ACCUBAKE RANGE, THE OVEN AND BROILER DOES NOT WORK. CHANGED SPARK MODULE AND STILL DOESN'T WORK. ANY SOLUTIONS?????
There are four other things to check on the oven, you will have to run a test on the broiler element, oven thermostat, selector switch and the oven cycling relay.
To test the broiler element, To access the broil element located on the roof of the oven cavity, first open the oven and remove the oven racks. Remove the screws that secure the element to the oven, remove the holding brackets from the element and slide the element forward.
There is normally a small amount of excess wiring attached to the terminals on the element that allow a little room for maneuverability (you may have to tilt the element to get the terminals through the holes). Look for loose or disconnected wires and if there is no sign of burning; reconnect the wiring to the back of the terminal. If a terminal end is damaged, replace it with a terminal end designed specifically for oven use only.
To test the broil element, remove the wires from the broil element terminals by removing the screws from the terminal or pulling the wires off the broil element terminal. Remember to label the wires for reinstallation.
Visually check the entire element for signs of burn.
Test the broiler element for continuity. Using the ohmmeter, set the range scale on R x 1 and place the probes on the element terminals. There should be continuity, with readings ranging from 19 to 115 ohms, however readings will vary from manufacturer to manufacturer and according to unit size and the wattage, be sure to check your manual for the manufacturer's specifications.
If there are any signs of element burning, or if there is no continuity, replace the element.
To test for a grounded broil element, place one probe on the element outer surface and the other on the element terminal as in the ground test for the baking element. If continuity exists, the element has shorted and should be replaced. Be sure to test both terminals.
To test a dual broil element, remove the wires from their terminals. Using the ohmmeter, set the range on R x 1. Place the probes on terminals A and C to check for continuity, followed by terminals B and C. To test for a grounded element, place one probe on the element outer surface. With the other probe, touch terminal A, followed by B and then C. If continuity exists, the element has shorted and should be replaced.
To install a new broil element, simply reverse the disassembly procedures and reassemble, being sure to follow the wiring diagram and install the wires to the correct terminals
To test the oven thermostat: Access the oven thermostat, which is located in different places depending on the make and model: On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components. Some built-in models have a removable backsplash. Lift the backsplash, rest it on the cook top and remove the screws from the backsplash, which holds the rear panel. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
To test the selector switch: In order to gain access to the oven selector dial, first move the range away from the wall and remove the back cover panel by undoing the retaining screws. This will expose the back of the oven selector dial. Note: There are many styles of ranges. If this does not describe your range, refer to your owner's manual for instructions on gaining access to your oven selector dial. Now you can begin to test each pair of switch contacts for continuity with your VOM. Using the ohmmeter function, set the range scale to R x 1, and touch one test lead to each terminal of the switch contacts to be tested. There will be several pairs of contacts, one pair for each setting (eg. broil, bake, etc.). Refer carefully to your wiring diagram (often placed on the inside of the access panel) when testing. It is a good idea to label the wires as you test and only remove one pair of wires at a time. If there is no continuity between any pair of contacts, the switch is defective and must be replaced. To install a new oven selector dial switch, remove the old switch from the control panel by undoing the nut or screws holding the switch in place, leaving all wires attached. Transfer the wires one at a time from the old switch to the correct terminal of the new switch. Check your wiring diagram to make sure all wires are on the correct terminals. Now mount the new switch to the back of the control panel and replace the cover.
To test the oven cycling relay: In order to gain access to the oven cycling relay, refer to your owner's manual. Removing the back panel of the range accesses most relays, but some ranges locate the relay under the oven compartment where the utility drawer is usually located. Now you can test the relay using your VOM. First, label each wire attached to the relay and remove them from the relay terminals. Using your VOM's ohmmeter function, set the range to R x 1 and touch one test lead to the terminal marked L and the other test lead to terminal H2. There should be NO continuity. Next, test the terminals marked H1 and H2. Again, there should be NO continuity. Finally, test the S and R terminals. Continuity should exist between these two terminals. If your relay does not pass all these tests, it is defective and should be replaced. To remove the relay, undo the two screws securing it to the range and replace with the correct new relay. Refer to your wiring diagram and labeled wires to ensure that the wires are on the correct terminals. Now replace the back panel or drawer and test the oven.
Hope this was helpful to you. Thanks for using fixya.
Jan 27, 2011 | Whirlpool Kitchen Ranges
My 10 year old Kitchen Aid convection smooth surface range has a broken dual element switch on LF element. My Canadian Whirlpool contact provided a replacement switch # as 8203538, which I purchased. The...
your model calls for the pt # 8203538 and is a good # the sw 688 may be alright but I would use the 8203529 / this is a 15 amp sw. and is the correct replacement .it's blue in color and comes with instructions to install . . we use this sw alot and it does not cause porblems . / you should ck other things like tight connections at the power cord as loose or bad wire connectons will burn out the sw . ck all the wire ends for discoloring and if so replace them with hi tempt crome ones . they work best .. hope this helps **** .. .
Jan 10, 2010 | KitchenAid KERC507 Electric Kitchen Range
Hi there, we have replaced dual infinite switch on our jennair range and cannot figure out the correct wiring for the new 12002125 switch....can you help...???
Follow the instructions below from partselect:
Attach the black wire(s) from the old switch (terminal 2) to the new switch terminal P1. Also attach the jumper cable to P1 and "jump" it to S1.
Attach the orange wire (old switch terminal 5) to S2
Attach the yellow wire (old switch terminal 4) to 4a
Attach the tan/(white?) wire (old switch terminal 3) to terminal 4 on the new switch
Attach the single red wire from the right front element to terminal 2 on the new switch.
Attach the 'compound' red wires (the ones that come from the left rear/outlet connection and is also attached to the right rear switch) to terminal P2 on the new switch.
There is no need to separate the compound red wires.
Best regards.
G.
May 28, 2009 | Kitchen Ranges
Dual element burner not working
You have to use a voltmeter and test the voltage where the wires connect to the element. If you have voltage (probably 240volts) then the switch is good.
You then remove the element, and check it with an ohm meter to verify that the element is open.
Sounds like the switch to me, but you have to check it
May 01, 2009 | KitchenAid KESC307 Electric Kitchen Range
Dual element on ceran top will not turn off kitchenaid ykesc307hw4
Apr 21, 2009 | Kitchen Ranges
Replacing a dual burner control switch
First, have you removed the wires from the old switch?
If not, then look on the switch, old or new, and see if there are numbers on the terminals. If so, just move the wires one at a time, terminal number to terminal number.
If you have removed the wires, then you will need to find the wiring diagram, which is most likely found somewhere inside the unit or on the back panel. You should be able to identify the correct wire connection from the wiring diagram.
If you can reply the full model number, I might can find a wiring diagram for it and give you more direction.
Jan 22, 2009 | Kitchen Ranges
Wiring hookup for a replacement part
Mar 15, 2008 | KitchenAid KESC307 Electric Kitchen Range
Need wiring solution for replacement part
New switch problem:
Now for the wiring:
L1 Black (RL1) 2 P1
H1 Red 3 4
P Dark Red 5 S2
Open Questions:
Kitchen Ranges Logo
142 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
