Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore Trio 596.735073200 Frig & Freezer aren't working
Neither my refrigerator or freezer are cooling. I noticed last night that everything in the freezer was pretty much melted. I cleaned the condenser coil in front with vacuum {much much dog hair - I'm ashamed to admit} and then pulled it out and vacuumed the back fan outlet grille. I read your comments about evap fan motor failures on these models. I can't find an electronic board or a tech sheet. I took off the bottom plate in the back of the unit and I honestly don't know what I'm looking at and the manual doesn't help. However, when I plug it in, I can see the fan is runnning. Any ideas??
  • Sherri R Jun 01, 2008
    My temp on the refrigerator is 77 and the freezer is 10. I tried to clean the coils but how do you really reach them. I did vacum behind the unit and under the unit. But at this point I have seen no change. Any ideas about really getting to the coils, I took I a few screws but no real access.
  • 828 Answers
Behind the removable toe plate at the bottom front there is a wire grill condenser. Using you vacuum cleaner and crevasse tool clean it out as best you can. Sometimes it helps to blow out this area with compressed air.
Next look for frost on the back wall of the freezer section. If there is frost you have a defrost system problem. Let me know what you find.
Posted on Jun 03, 2008
Refrigerator starts cooling mainly when I open the door
Put a thermometer in both the freezer and the fridge. Fridge should be around 40F if not a little lower, but should stay above 30F.
Freezer should be just below 30.
Feb 09, 2012 | Refrigerators
The top frig is not cold at all , as if the motor stop or something
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 17, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
I have a Kenmore refrigerator not cooling
You will need to replace the heating element, if it looks blacken, then it's not good. When good, it's a clear glass tubing with a coil that heats up. Call Sears for parts.
Jul 20, 2009 | Kenmore 50522 / 50524 Side by Side...
Frig and freezer not cooling. Everything is thawing
1/ refrigerant leak or
2/ Defective thermostat / sensor or
3/ Burnt out compressor
Apr 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The Freezer and Refrigerator has stopped working completely
first check to see if the compressor and fan on the lower back of frig is working,if it is then check the freezer to see if the freezer fan is working,if it is then find the defrost timer(most of the time behind the front grill or inside frig. or on lower back)turn it til it clicks,wait 30 minutes and see if it comes out of defrost(you k=will know this if the freezer fan comes back on,let me know what you find-mike
Apr 16, 2009 | Refrigerators
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
My Kenmore Trio refrigerator (#596.76502500) is not working. The temp is 76degrees. The freezer seems to be working fine. I have switched it off at the circuit breaker and restarted it after 10 min. The...
The fan that blows cold air from the freezer to cool the refrigerator is not working. If your a little handy with tools its an easy fix. Its located in the freezer. Open your freezer door take off the steel panel at the back of the inside of the freezer. After you remove the panel you will see the fan the blows the cold air up to the Frig. A quick trip to a local appliance store for a new fan with do the trick. Put in the new fan 100% fixed even better than new because the orginal part is defective Kenmore should have recalled them. I have the same frig and its been perfect since I repaced my failed fan.
Aug 04, 2008 | Kenmore Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
111 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
