Question about Farmall IH Tractor 460, 560, 660, 2606 ITIH25
Is a ih 460 positive ground - Farmall IH Tractor 460, 560, 660, 2606 ITIH25
  • 24 Answers
This one is easy to figure out. You can use a voltmeter or a 12 volt light bulb. Please one lead (wire) to the frame of the tractor and the other lead on a battery terminal. If the lamp lights when you place the lead on the POSITIVE terminal (or the meter reads 12 volts), it is a Negative grounded system. If the Lamp lights when you place the lead on the NEGATIVE terminal, it is a POSITIVE ground system.
Posted on Oct 09, 2010
Testimonial: "very help full thank you"
Ih serial numbers 1922
need to know what model this tractor is or go to www.tractorpart/farmall_trator_serial_number.html it will list them all out hope that helps
Aug 22, 2014 | Farmall IH Tractor 460, 560, 660, 2606...
Ih 574 firing order
firing order of 1342, rotor turns clockwise when viewed from the rear
Jun 06, 2014 | Farmall IH Tractor 460, 560, 660, 2606...
460 diesel farmall - having issues starting and have recently replaced glow plugs and still having issues starting tractor
look at the instructions again and if it still doesn't work bring it back and explain to the person what happened
Apr 16, 2014 | Farmall IH Tractor 460, 560, 660, 2606...
Dash layout on farmall 560
The operators manual shows a cigarette lighter in that location. It would be just to the right of the starter button. I have an IH 560 diesel, so that's where the glow plug button is located.
Jul 29, 2012 | Farmall IH Tractor 460, 560, 660, 2606...
Where do you check hydraulic fluids on a 460 international tractor
I own one. Most have a plug in the top of the trans/hydro case to the left and rear of the gear shift leaver. It takes a 3/4" drive to open it. I use an extention and brake bar or ratchet. The fluid should just all most reach the opening. the books state it should hold 8 to 10 gal. I have found my 460 Utility holds almost 20 gals.
Jan 04, 2012 | Farmall IH Tractor 460, 560, 660, 2606...
I have an international 460 tractor and i ma trying to find the serial number. All I have found for a number is 10865, but that doesnt fit into and of the serial number references that I have found. Does...
I have a International mid sixties 460 tractor. Have drained fuel, changed fuel line and filter. Carb has been taken off cleaned no issues. Will start and run for a few minutes sometimes longer than others. Seems like there may be an issue with the governer. Any ideas what to try next. Thanks
Jan 15, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
We have an IH 460 Farmall. It ahs been running
check the carb out clean it and the lines also just to be sure check the sparkplugs
Oct 11, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
What kind of hydraulic fluid can i use in my farmall 460 that is affordable
universal hydraulic fluid is all we use it is used for the transmission and the hydraulics, about 25 bucks for 2.5 gallons, put in at the gear shift until it comes out plug below cluch pedal. Check any cenex gas station .
Oct 09, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
Farmall IH  Tractor 460, 560, 660, 2606 ITIH25 Logo
351 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Bud H
Adam Plug
Adam Plug
Are you a Farmall Toy Expert? Answer questions, earn points and help others
