Question about RIM BlackBerry Curve 8310 Smartphone
Hi\r\ni have a blackberry 8310. i have had no problem as it has been 02 simcard but now since i synchronized phone to my pc, i dont have a mobile connection. it shows off. how do i fix this??
  • 9 more comments
  • massha Oct 09, 2010
    hi
    i have taken out battery and sim and put them back in and put the phone on.
    when i put the phone on.. it shows in the right top corner "off".. how do i put the connection back on?
    its not detecting the O2 sim card now and i need to put the connection back on..
    the problem of this occurred when connecting pc to mobile through usb lead
    Thanks
    hi
    Thanks
    hi
    perfect i was just looking at the manual.. and i went manage connections. It works now.
    Thanks
    could you just please tell me how much will i be charged for this?
    I have got this blackberry 8310
    other problems
    calendar appointments and texts messages over a week old get deleted automatically even though i stated that keep messages and appointments forever, why does this happen?
    i have even today looked for any updates for my phone but there was not any!
    could you please advise
    how do i keep my texts messages and calendar appointments saved forever because at the moment on my blackberry 8310 they get automatically deleted over a week old.. i have found it is not software issues either..
    could you please advise!
    thanks
    hi
    this issue with texts messages and calendar appointments being losts is a problem before i even started using my pc to connect to my mobile.
    i only connected today because i wanted to try and save calendar and texts to pc so they are not losts.
    How can i keep calendar appointments/texts messages for ever on my phone as i have made sure the settings are on forever!
    Also if i do a backup on my mobile and then i restore that backup on my phone later, will i lose the current data at that time?
    hi
    blackberry 8310 is rubbish for internal memory and sad fact you cant save txts, emails and applications to sd external memory card which i have 4gb.
    so i have downloaded a few applications. i guess to resolve the problem i will have to remove a few applications and then this would be fine..
    there is no other way?? when i reset phone then my status file free is bigger, if i do that more often , wil i be able to save texts and calendar??
    thanks
    Thanks for your all help
    A*** Service
    i got my answers.. take care
    bye for now
    Excellent Ginko did a great job :-)
  • massha Oct 10, 2010
    hi
    refman16 solution does not seem to work, i think that option is for bb pearl only. do you know how to clean memory for bb curve 8310?
    thanks
    thanks
  • RIM Master
  • 19,396 Answers
Hi.
If you only sinchronized the Blackberry with the computer, without installing any firmware, then all you have to do to reset the phone is removing the battery and restarting the phone.
If that does not work, then there is an additional problem. In that case it is pretty unlikely that simply sinchronizing BB with the computer has caused the problem.
Posted on Oct 09, 2010
  • 6 more comments
  • Ginko
    Ginko Oct 09, 2010
    Hi, try going to profiles and choose normal profile.
    If that does not work I will give you instructions for doing an hard reset, but that will reset phone to factory settings, deleting all data stored.
  • Ginko
    Ginko Oct 09, 2010
    Also go to Manage Connections option in menu and ensure that network is turrned on. If SIM is not accepted test SIM on a different phone (test using an unlocked one)
  • Ginko
    Ginko Oct 09, 2010
    Most important thing at this stage is that you click on the Manage Connections icon and turn all connections on. Try that, if that does not work, we go for a reset.
  • Ginko
    Ginko Oct 09, 2010
    Hi.
    I think you are charged a one-off $6 fee, I am not sure. The expert answering the question gets only a $2 reward that is credited if you accept the solution, the rest of amount charged goes to the company.
    Regards.
    Ginko.
  • Ginko
    Ginko Oct 09, 2010
    RE:"other problems
    forever, why does this happen?"
    Through computer connection you can do a reset. That is probably what happened. When this happen the only way to recovery your data is if you did a backup before resetting. Unless you have a backup file you won't be able to restore the data.
  • Ginko
    Ginko Oct 09, 2010
    Hi.
    The BB deletes messages and stuff when it goes out of memory.Go into options, then status and check the free space allocated ot files, if this is below 150K the files will be deleted. Also ensure that contacts, messages etc. are not being saved into the SIM card memory.
    I think that you are experiencing all this problem because BB memory is full. BB uses three storage devices (memory): Phone internal memory, SD card and SIM. Check SD card,if that is full replace the memory card with bigger one. As said also ensure that you are not using the SIM memory. SIM has very little memory up to 256K, better not using it on a BB.
  • Ginko
    Ginko Oct 09, 2010
    Hi.
    Yes I know. Fixya has a couple of threads on the topic. Here one example.
    Scroll down the thread and see the hint from refman16 for clearing logs, that can help a bit.
    Thanks for the feedback.
    Have a good day.
    Ginko.
  • Ginko
    Ginko Oct 10, 2010
    Hi.
    Save your data first.
    To clean everything go to options > security options > general settings, then press menu and the select wipe handheld (wipes everything)
    To clean logging only Menu > Select Options > Call Logging. Set to None.
    Here a page that may help.
    Take care.
    Ginko.
Tip
BlackBerry - Synchronize data between mobile and computer
<ol> <li>Firstly you need to connect you blackberry device to you computer </li> <li>Then open BlackBerry Desktop Manager manual, if it didn't open automatically when device was connected to computer</li> <li>Then when the application is up look for synchronize and click it</li> <li>After which you will select the check box beside one or more action </li> <li>Then click synchronize </li></ol>
on Jan 08, 2011 | Cell Phones
Paano ko maa activate ung gprs ng cherry mobile cellphone unit ko
Hello Annalyndael,
You can do that by calling your mobile service provider and request them to activate it for you. Iba iba kase ang settings bawat phone and bawat service provider. Halimbawa sa Globe, iba ang settings sa Smart and iba din sa SUN. Kaya kapag ni setup mo yang phone mo for Globe GPRS, kapag nilagyan mo ng SMART na simcard, hindi din gagana ang GPRS.
So, tawag ka po sa globe/smart/sun or kung ano mang simcard ang gagamitin mo, tapos sabihin mo na ipapa activate mo yung GPRS ng phone mo. Dapat alam mo din yung model number ng cherry mobile phone mo para mas madali nilang ma-activate.
Pakirate naman yung sagot ko.
Thanks for using Fixya!
-damneddle
Oct 06, 2011 | Cell Phones
My blackberry phone has a problem -invalid simcard. but when i inserted the same simcard to another phone there is no problem at all.what should i do?i know that my phone is something wrong
Hi,did you got your blackberry for contract? if so then thew mobile will not allow you to accept you to insert other provider's sim unless otherwise you unlock your mobile..and when you inserted your sim in other mobile,means that the mobile will be unlocked(assumed) or it will not be purchased under contract..so try to unlock your mobile to use other provider's sim..for unlock codes you can either contact your provider or can get it from online providers..once i got unlock code for my mobile from theunlockspot and unlocked my mobile..you can too try getting codes for your mobile..but before that check whether unlock codes are available for your country and provider..
Sep 03, 2011 | Cell Phones
How does one.... 1.) copy all contacts from phone to simcard and 2.) from simcard to phone memory I have a Blackberry Storm 9530
Under Contacts press the Menu button, you will have a copy option where you can select from SIM card to Phone.
The Blackberry mobile software does not have an option to copy from the phone to the SIM card.
Apr 10, 2011 | RIM BlackBerry Storm 9530 Smartphone
Tell me about the cu920lg phone net i dont know
Hi!
In order for you to surf the internet using your mobile phone, first, you will need internet settings save on your phone. These files are usually sent to your phone once your service provider detect your phone is not yet setup to be used as internet browser.
If you are in Afghanistan. The service provider is the one who made your simcard. (make sure this simcard is 3G) Once you insert the simcard, your network provider will send Phone Settings on your phone. Just save this files. If it don't, then, you will need to call them and ask for the phone settings for your mobile phone.
Hope this helps!
Dec 27, 2010 | LG Computers & Internet
How do I load and coordinate my MS Outlook address book and calendar with my Blackberry Curve 8330?
Here is how you do it:
1Install Blackberry Desktop Manager Softwarewhich included in your Blackberry Installation CD. If you don’t haveone, you may download software from Here
2Make sure you set an Outlook profile that the Desktop Manager can use.3Start the BlackBerry Desktop Manager.4Connect your Blackberry with your computer via USB cable and allow Blackberry device driver install.5Click on Synchronize in BlackBerry Desktop Manager.6Activate the Synchronize organizer data checkbox: BlackBerry Synchronize.7Click on the Configuration tab. Then, click on the Configure synch: BlackBerry Synchronize Configuration.8Check the data you want your BlackBerry being synchronized to. Choose CONTACTS, TASKS, CALENDAR, and NOTES databases.9Afteryou check each item, the software will ask which application you wouldlike to sync it with, you will choose OUTLOOK for all.10Nowgo back to the Desktop Manager. Make sure that the SYCHRONIZE ORGANIZERDATA check box is checked. And select the Synchronize now button at thesynchronize dialog to begin synchronization.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Dec 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
PUK Code
Hi,a PUK code is for your simcard and not your phone,
Another sim will work ok in the phone,
Your simcard has been blocked due to entering the wrong pin code 3 times,you need to contact your simcard/network provider who will be able to supply you with the PUK code to ublock your simcard,there should be no charge
- Some network providers have an online automatic service for retrieving the PUK if you check on their website,
You enter your mobile number and the PUK code is generated
Sep 07, 2009 | RIM BlackBerry 7520 Handheld
HOW TO TRANSFER PHONE BOOK FROM NOKIA 6300 TO BLACKBERRY
Hi
I transferred all the contact names from Nokia N73 to Blackberry Bold 9000 using this method:
1- Fire up the Nokia PC Suite and synchronize to Outlook from Nokia (this will send all contacts from Nokia to Outlook.
2-Fire up the Blackberry Desktop Manager and synchronize from there and this will take the information from Outlook to the BB.
You are done.
Hope this is helpfull.
Khalid Alansari
Mar 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
CUBE
Is the model no. selected right?? What do you mean by "Rejected Simcard" - Is it expired?
Check out the official site and find out the manual for your T-Mobile:
Blackberry T-Mobile
Frankly speaking, I dont know much about T-mobile, so for any further support, please contact Blackberry or see FAQ:
Support
Oct 22, 2008 | T-Mobile BlackBerry 7105t Cellular Phone
RIM BlackBerry Curve 8310 Smartphone Logo
125 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
