There will still be water in the outer tub you will not be able to remove with the vac. and the pressure sensor will detect this. If the water isn't draining properly, pull the pump, inspect for pennies etc, if nothing found then replace the pump. I've seen these washer pumps go bad a few times.
Rich
Western Appliance Repair
Appliance Repair Meridian
The LD fault code indicates that the washer took longer than 5 minutes to pump out the water and reset the water level pressure switch. You should be able to press STOP/CANCEL to clear the display.
Check you drain hose for kinks or clogs. You could have a clog or failure in the drain pump that is causing this problem
