Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
When I puished the bottom storage drawer in there was a spark and now nothing is working I unluged it and plugged it back in ..nothing..I turned of the main electrical switch and flipped it back on ..nothing..what should I check?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
Pull the drawer all the way out and look at the wiring or where exactly the spark could have come from. Many times there are ignitor wires, valve wires, etc. that could have been shorted.
Rich
Western Appliance Repair
Washer Repair Boise
Posted on Oct 09, 2010
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Jun 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Storage drawer wont open
Yes,but try this. Slide a clipboard into the opening whee the blockage is and then work the board back and forth to see if you can settle the utensils down. Shake the drawer at the same time. This should do it. A little time with and the extra racket should work.
Feb 24, 2013 | Kenmore 30464 / 30465 / 30469 Gas Single...
My Frigidaire 30" gas stove is not leveled from
If you remove the bottom of the range, where the pan storage drawer is, you will see the leveling legs there, and you can use those to level the machine. Don't use pliers if you can avoid it, find an adjustable wrench or an open end wrench, the ones on mine are 7/16th. You can use a measuring cup filled to a line level, and place it on the stove as you move the legs, then you can better adjust them. Do so until the water levels off at the line you filled to. A final test will be to place a flat pan and only drop a couple drops onto it, and see if this runs to one side or the other.
Hope this helps, Please rate and comment, Thank You
Joe
Sep 17, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool RF385PXEN COMPLETELY DEAD, NOTHING WORKS,checked the obvious like breaker etc..what is next step. I`m skilled with a VOM Meter, thx
Most ranges from that brand have a high limit thermostat behind the back panel, or sometimes under the burners,it should be closed if good. typically the wiring diagram is either inside of control panel or hidden under the storage drawer.if it has the high limit (also called thermal fuse) the diagram will show you the color wires to it.
Gene
Aug 05, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I am having trouble with the electronic ignition lighting the gas burner in the oven. It makes the clicking sound, but there is no spark 75% of the time. Gas flow is consistant every time. It is a model...
I tried the one thing no repair person or manual ever mentioned: take out the bottom drawer, which is used for storage, and check the wire connection under the stove that connects to the ignition wire. If it is loose, disconnect at the spade connector, clean, and re-attach. Now it works fine.
Dec 10, 2009 | Kenmore Ovens
Electric warming drawer will not heat
Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
Feb 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Can't find the model number of my Electrolux electric oven
Model number should be down on the bottom where you pull out the storage drawer either the left or right side. If it's not there it'll probably be right behind the controls on the back panel of the oven. There also should be a tech sheet in a plastic bag on the back of the oven when you pull it out. That might tell you how to convert it back to ferehite. Good luck.
Feb 15, 2009 | Ovens
Smoking Kenmore
Hello oliver909
Welcome,
You said,Smoke is coming out of the back of my gas Kenmore oven. Oven is clean - no spills/debris. Ran clean cycle and broiler did not smoke. Warmer drawer at bottom, so nothing spilled there. Soon as you turn it on, downstairs is full of smoke. Sometimes after preheat goes off, smoke clears and its fine. But I'm afraid to use it because last time I saw a flame inside.
If your afraid to use it, do not hesitate to call service. Nobody wants a fire!
Huuum
Oct 09, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
Burners & clock are working, but oven, brioler & self-cleaner won't. Error F-0, EO
Brandyz Most likely the problem with your range is the spark module. It is located in the control panel on the right hand side. You can access it by removing the back panel held with four screws from the back. Remember to unplug the range first. The name plate with the model number and the serial number is on the frame behind the storage drawer. You can buy the spark module here: http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.545301030&type=10&subid= It comes with installation instructions. Gendos...post back
Jan 30, 2007 | Whirlpool RBS245PDS Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
