Question about Panasonic PV-GS31 Mini DV Digital Camcorder
Cannot see screen or what has taped after taping it. What can I do to see the screen or to watch this tape? Any solutions? Sounds like it is taping and shows through screen like taping, just won't play back.
    Genius:
  • 1,812 Answers
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 10, 2010
Tracking appears to be off, when trying to watch a recoded program from the tv, the tape flickers and rolls.
It sounds like your video head is dirty, there are three options, use a wet tape to clean the heads, I recommend the dry tape, much easier on the mechanical parts and head. The third approach is get a brand new blank T120 tape, set the vcr to sp and let it run the full two hours, this is ideal for prolonged cleaning and natural to the machine.
Feb 04, 2011 | Philips Televison & Video
Vhs tape won't play
sounds like to me the tape is to tight .try rewinding the tape all the way then fast forward all the way till it stops repeat and it should loosen up. if not the tape is no good the blue screen might go away after the tape is loosened n try cleaning the tape player good luck
Sep 19, 2009 | JVC DF420 D-VHS Tape
I have a yellow tape blinking in the screen what does that meen??
It could mean several things. You should check your manual or go to Sony's website to find the most accurate answer.
However,here are some possiblities:
No tape
Almost full tape
Full tape
Damaged tape
If this helps please vote for my solution.
Sep 02, 2009 | Sony Video Cameras
Panasonic PV-GS39 -- Eats Tape, Reset Button, Playback Problems
ya sounds like a bad tape loader. your estimate sounds about right. tape sensors also go bad so I would have them check it also.
Jun 01, 2009 | Panasonic PV-GS19 Mini DV Digital...
Stuck VHS Tape/Power Issue
It sounds like the vcr is not completely loading the tape, and is overloading or getting confused. If you feel up to it, you can take the cover off the tv, find the tape loading mechanism, and 'help' the loading rollers along yourself... once the tape loads, eject it immediately, and you should be off and running again. Just be careful not to touch any electrical connections. If you're not comfortable with that, you're right, it's probably cheaper to get a newer tv - check with a local independent shop first, though, it should be a really quick fix.
Mar 14, 2009 | Samsung Televison & Video
Tapes no longer reading after head cleaner tape used
Sounds like your cleaning tape deposited too much cleaning solution on the tape head. I would purchase another tape cleaner and run it though the machine WITHOUT any liquid cleaner on it.
Try your tape then.
If you still can't get it work, then your cleaner prob damaged the head. You will need to send it in for service.
Jan 02, 2009 | Sony Hi8 Cleaning Cassette / Head Cleaner...
Stupid tape.
Use good quality video head cleaning tape to clean video head in camcorder.
Apr 20, 2008 | Sony (41989) Hi-8 Tape
HELLP ME
This sounds like it could be a tape sensor problem. Granted this is the worse case, but this is what this sounds like. In VCRs as the tape is pulled around the drum, a sensor determines if the tape is in the proper position. However if the tape is not the sensor triggers an unload sequence which unloads the tape and sometimes auto ejects the tape. I would forst try to use another tape just to see that it is not a tape problem (which 9 times out of 10 it will not be). After trying the new tape, see if you can get this looked at, by a qualified technician. I have done these repairs before and if it is an optical sensor what usually happens is magnetic dust gets on the sensor lens and causes problems, if the sensor is the switch type the switch tends to get out of alignment and needs to be set correctly or replaced. I hope this helps
Jan 10, 2007 | Jwin JD-TV1300 13 in. TV/DVD Combo
All of a sudden some of my tapes will not playback and others will??
I have been experiencing the same problem with my Panasonic PV-GS120. I don't know the root cause or real solution, but I found if I keep playing the tape, rewind->play->rewind->play, eventually I would get the image back normal. I think I would try to clean up header with a header cleaner to see if it helps or not. If not, I plan to submit a request to Panasonic support to check out possible solution. Good luck.
Oct 22, 2006 | Panasonic Palmcorder PV-GS120 Mini DV...
JVC camcorder GR-D350U
You have a clogged video head. Use a dry type head cleaner and follow the instructions. Better use the best tapes you can afford, since tape quality can keep you from having this problem, and tape cleaners can gradually damage your camera. Good luck
May 27, 2006 | JVC GR-D350 Mini DV Digital Camcorder
Panasonic PV-GS31 Mini DV Digital Camcorder Logo
41 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
