Question about Whirlpool MT9160XE Microwave Oven
MY MT9160XEQ-0 MICROWAVE JUST QUIT. I THOUGHT THE ELECTRICITY WENT OUT BUT DID NOT. ANY SUGGESTIONS
Should i keep the capacitor installed in the microwave before testing? Should i plug the microwave to electricity. Before testing?
please do not proceed. blown fuses is usually because of a bad door switch. there are three or more on every m/w. triple redundancy so high voltage radiation wont leak out and cook you instead of your food. or some times a shorted high voltage capacitor. ! it stores 2000 volts and can kill no joke. so discharge it with a plastic handle screwdrivers :) electricity "its SHOKING "
Jan 06, 2015 | In Microwave Ovens
Instructions on how to remove the cover from a wall mount LG LMV2073 mic oven?
On my GE, if you open the door, there are screws to remove that will allow the cover to be removed. When it quit working, I had to show the guy how to remove it. He thought he had to take it all the way down. Turned out to be the fuse (which I could not see when I had it opened) so he charged me half the cost to come out because I had to show him how to open it
Oct 30, 2014 | LG Over-the-Range Microwave
Looking for info on kitchenaid microwave
Your microwave oven is an old timer in terms of appliance years. It may turn ou that replacement is the only practical solution.
Nov 21, 2013 | KitchenAid Microwave Ovens
Microwave will not cook or heat anything. Cooked a bag of popcorn just fine, tried to cook a second one and nothing happened. I thought the bag of popcorn was bad but it won't even heat water.
sounds like the magnetron has went out...this is the device that actualy converts the electricity into a heating source ... it is a common problem and can be costly,,it is not very hard to change just requires pulling the microwave if it is a cabinet mount and taking the exterior cover off and getting to the magnetron...the problem is the cost of the magnetron is normally somewhere in the range of a $100.00 and your time alot of people choose to get another one due to not being that much more expense and the work involved to repair yours.... good luck hope this helps...
please vote.....
Jan 03, 2011 | Frigidaire GLMV168K Microwave Oven
Our microwave all of sudden quit working. Had no
Hello :
Maybe there's a problem with the power transformer or the power PCB [ Printed circuit board ] . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service for repairing .
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1540 Microwave Oven
GE Advantium Oven - LED lights went out.
if anything like my own it is the led blub thats blowen - major hasel to change out - get some one who knows these cookers/ovens...
Aug 07, 2009 | GE Monogram ZE2160SF Convection /...
Whirlpool MT9160XE Microwave Oven Logo
300 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
