Question about Dell 3000cn Laser Printer
Dell 3010cn How the heck do i install this black tonner cartridge for this printer? I just started working here on MOnday cantfind Manual.. Look like they rotate?? Can't call it need help
After a state of confusion I have figured it out. Hit the menu button. Hit the down arrow botton to choose the color you would like to change. It will rotate to that color. From that point you can then follow the instructions that are on the toner box.
Posted on Feb 18, 2009
  • 3 Answers
Open the front cover, on the left side there is an you will see a small opening in line with the toner. I used a folded peice of paper to press the small lever inside the opening. This will allow the toner carousel to turn. There is a groove that aligns with a notch on the toner cartridge. Line this up and you should be able to remove the cartridge.
Posted on Oct 05, 2008
I changed the black and all 3 color cartridges and now it leaves wide streaks of color. How can this be corrected?
If you used a compatible cartridges your problem is probably in the cartridges, replace them. If those are genuine dell cartridges get back to me. Good luck.
Dec 14, 2010 | Dell 3010cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
I wish to replace the black toner cartridge in the Dell 3010cn. How do I gain access to it. There is easy access to the cyan cartridge at the moment
if you want to replace black one only you should follow these steps Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
plz do rate the solution if got help
Nov 25, 2010 | Dell 3010cn Laser Printer
I'm receiving a 010-397 Waste Toner is full on my Dell 3010CN. How do I correct this?
Take off your Tuner Carrier and check if it even hold it in your hand and tap on the side cafully... Maby all the tonner are on the same side.... Sometime when your move or tip the printer on the side little bit it became dirty iside So make shure your Drum are clean first dont put any product... Just clean it with a dry clothe
Sep 22, 2010 | Dell 3010cn Laser Printer
How do i replace drum cartridge?
pull open the front cover lift up the top cover lift up the blue handle on the right pull the blue handle in the middle up that is the drum unit steven 818-888-0006
Apr 26, 2010 | Dell 3010cn Laser Printer
Vertical line on copies
A vertical line on laser copiers which are the same lenght apart on each indicates a dirty or defective toner cartridge or dirty or defective rollers. Take the cartridge out and wipe the rollers with a soft cloth. If the streaks continue then the rollers inside the cartridge or damaged. You will need to replace the toner cartridge. Let me know if you have any questions. Please rate this solution with 4 diamonds.
Mar 29, 2009 | Dell 3010cn Laser Printer
Dell 924 printer problem with black cartridge
Dell printers donnot seem to work on refilled cartridges. Do buy new cartridges to fix the issue
Apr 08, 2008 | Dell 924 All-in-One InkJet Printer
Dell 3000cn Laser Printer Logo
158 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
