Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Will not spray hot water/cleaning solution mixture
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Oct 09, 2010
Bissell lift-off deep cleaner pet will not spray solution either mounted or lifted out for upholstery use.
Sounds like either the pump quit or plugged, or if you here pump nozzles clogged. Try 2 cups of vinegar and water to help clean out
pump and nozzles. Let stand 1/2 hour, then shake it up with mixture in it, do this a few times then try and run mixture through machine
press the helpful button and follow me on Fixya for more good tips
Jan 27, 2016 | Bissell Vacuums
How much soap and water to mix for steam vac
Hi! To fill the solution and clean water tank, turn tank upside down and unscrew cap. Pour Hoover cleaning solution into tank to detergent fill line. Then fill tank completely with hot tap water. Hope this helps!
Jul 10, 2014 | Hoover F5505 SteamVac Spot Vacuum
Windsor fiber pro 20 Betco extracter not spraying out enough water
clogged nozzel run some hot vinegar through it... then some plain water. (do this in a dry bathtub.)
Dec 29, 2012 | Vacuums
Will not spray water
When this happens you usually have a blockage in the tubing. Old cleaning solution gets dried up and hardens and then blocks the tubes. You need to take the tubing off and clean it all out or untill you find the blockage. Once you get it spraying agin clean the system with hot water and flush it all out. Always spray just water for a while after you use any cleaning solutions and this will keep the tubing cleaned out. Does this help? do you need more assistance let me know.
Nov 19, 2010 | Bissell PowerSteamer Deep Cleaner Plum...
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
Can you disperse a water and vinegar mixture with the steam buggy, without causing damage to any part of the unit? can you disperse a water and bleach mixture with the steam buggy, without causing damage...
If you do this the vinegar will likely disperse hard water scale as it cleans the inside of the element. While it shouldn't stain anything it will likely cause sputtering as it breaks down the scale. If your goal is to clean and disinfect a surface that is vinegar friendly, I would consider taking the extra step of spraying the surface with a spray bottle with the vinegar. Bleach in steam might puff back at you in a cloud and burn your eyes and skin so be VERY cautious on the bleach.
Sep 16, 2009 | Tristar SB Steam Buggy Vacuum
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet cleaner
If water is spraying from the tool hose, then check the heater for a blockage. If the heater port is blocked, then the water can't flow back down to the spray nozzles, which could also be clogged. Most likely a clogged heater, it is in the handle.
May 11, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissel 1770 Quicksteamer II Upright vacuum
Here is a picture breakdown, maybe that will help. Sometimes tho you can run a mixture of vinegar and hot water thru it, it may clean it out ok.
Mar 25, 2008 | Bissell 1770 Quicksteamer II Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
48 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
