Question about Microwave Ovens
Where is the thermal fuse on an electric whirlpool oven....in cabinet style
  • tgood333 Oct 09, 2010
    model number RBD245, 275, or 305. it is an electric oven that fits in the cabinet in kitchen. It is not a microwave. It has digital controls..no knobs.
    Are you telling me it does not have a thermal fuse? The oven quit heating after we used the self cleaning option. when i called a few repair men they all told me the thermal fuse was most likely blown.
  • 1,711 Answers
What is the model of your oven. Also is this a microwave or standard electric oven
Posted on Oct 09, 2010
  • espressonist
    espressonist Oct 09, 2010
    The oven temperature safety switch is located behind the back panel-chassis internally in the oven. You can use the light of the oven if it can light or use a flash light to find a hole on the panel and recognise its reset push button. Use a screwdriver and push once in this button, if you can here well you will hear a click meaning that the thermostat is reset to on position again.
    We have here a link with parts layout showing the safety oven thermostat
    http://www.appliancepartspros.com/partse...
    Is the part number 13 at the Upper Oven page 2.
    Sw/ov temp - Oven temperature saftey switch.
    Part Number: AP3126283 made by WHIRLPOOL
    Just a note after resetting the safety thermostat you should work it with care in order to be sure if it was triggered accidentally off or if there is a problem in electronic control.
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=239620&diagram_id=23494#d23494
  • espressonist
    We are talking about the same thing safety thermostat is a thermal fuse.
    Just to confirm the model of your oven have some more letters after RBD245 like RBD245PDB2 or RBD245PDQ1 or similar . So can you confirm exactly the model of your oven.
Where do i locate the fuse
Although you have not mentioned the model/make, take a look at the video here for replacing a Thermal fuse. Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
on traditional fuse see
How to Fix Microwave Oven Simple Fuse Replacement
Mar 08, 2016 | GE Microwave Ovens
Panasonic Microwave NN-CT552W has no power - plug fuse ok - Has it got a thermal cut out or internal fuse? - Unit was ok after cooking some jacket potatoes
All microwaves has both internal thermal cut out and internal fuse, Yours problem sounds like an open 9 volts transformer that power up the front panel
Nov 07, 2014 | Microwave Ovens
My model mmv5000bdw
Most likely a fuse or thermal cutoff device (TCO or thermal fuse), usually mounted on top of the oven cavity, between the oven cavity and the outer cabinet panel.
Sep 08, 2014 | Microwave Ovens
How do I get to the fuse on my cabinet tappan microwave?
Then you have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Nov 28, 2013 | Tappan Microwave Ovens
What internal fuses for goodmans st101ss microwave
the modern microwaves has 2 fuses lines fuse+thermal fuse. You must see the diagram or instr. manual section troubleshooting for indication for specification of fuses. Lines fuses has 240vac and 20amps. Thermal fuses you must see the instr. manual
Jan 24, 2013 | Whirlpool GH8155XM Microwave Oven
It's completely dead?? Not sure what happened. Power supply is fine.
Microwaves that suddenly loose power could have many causes with the easiest being a blown fuse inside the cabinet of the oven. To check for this unplug the unit and remove the screws that hold the cabinet in place. Be sure to not touch any of the electrical components inside to avoid shock. Visually follow the path the power cord takes as it enters the unit. The fuse ( usually clear glass with metal ends and cylindrical in shape ) should be located not far from where it enters the cabinet. Once located use a fuse puller or other means to carefully remove the fuse to check the element inside. If the fuse is blown take it to a hardware or electronics store for replacement. These fuses are cheap as this has happened to me before. Good luck!
Jun 19, 2011 | Whirlpool MH6110XE Microwave Oven
Change fuse whirlpool mh6110xeb1
have to take cabinet off frame. several screws around microwave that holds the cabinet to frame.
Aug 26, 2009 | Whirlpool GH7155XHS Microwave Oven
Microwave went dead
Hi
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 26, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool microwave 2003 stopped working & inside light is on
The most likely cause is a blown fuse or a kicked circuit breaker. Look in the cabinet above the microwave and see if the microwave is plugged into the ou let in that cabinet. If it is plug a blow dryer or some other little appliance in to that same outlet to see if you have power there. If no power go to your electrical panel and either replace the fuse or turn the breaker off and then back on.
Mar 18, 2009 | Microwave Ovens
No power replace fuse
there are thermal fuses as well as the ceramic power fuse. one is located on the heating element(magnatron) and one on the cabinet. if the one on the magnatron is blown you more than likely have a bad mag as well. if it is the one on the cabinet it just got too hot while cooking
Jan 31, 2009 | GE JE1640 Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
