Question about Kenmore 43142 Front Load Washer
How do I replace the bellow on the Whirlpool front load washer?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
Easy, tilt machine backwards against the wall to give more working room. Remove Wire clamp around the outside lip of bellow. I use needle nose plyers to grip it. Once you have the outside part peeled back, use a 1/4 socket (I think) to release the large hose clamp that attaches the bellow to the outer basket. Install in reverse order.
Rich
Western Appliance Repair
Whirlpool Repair Meridian
Posted on Oct 09, 2010
Testimonial: "Thanks so much for your help. It was just the information that I was looking for. We are in the process of replacing the part ourselves & saving $."
jsrock516
  • 5911 Answers
SOURCE: Duet washer leaking
If the leak started occurring after the bellow was replaced, and it's on the left hand side of the door, I suspect the bellow is not seated around the fill tube all the way. I have experienced this problem before. Check the fill tube where it comes in by the door. The rubber should be seated back far enough to allow the tube to fill into the tub without obstruction. It could be that the fill tube is forcing water BEHIND the bellow and leaking into the washer and on to the floor. To answer your question, "YES", replacing the bellow could have caused your leak.
Posted on Sep 29, 2007
aborcass
  • 2651 Answers
SOURCE: How to replace the door bellows seal ?
did hte rear clamp come off or just the front spring. assuming its just front spring.carefully reinstall the boot over the front lip assy . easy enough!!here comes the fun!! the spring itself goes to the bottom of the rim.So hang the wire over the top of bellow and feed into the lip evenly as you go down both sides as soon as you get your hands to the 9oclock and 3 oclock positon I then change grip on the spring (use the tips of my fingers palms facing front assy and strech whole pushing down and in. I used to find small spring style clamps would work great for holding the wire in place till it would "pop" into place. a third hand is also very useful to hold in place .
Posted on Mar 12, 2008
jsrock516
  • 5911 Answers
SOURCE: How Do I replace the
Here ya go, click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the instructions thoroughly before starting. This is a fairly straight forward and simple repair job. If you require further assistance, go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
Posted on Jun 16, 2008
  • 49 Answers
you must remove the large front panel. if you can manage that the rest will become clear to you. dont forget to unscrew the door lock before befor removing the front panel. you will find three screws at the bottom of the front panel under the kick panel, remove them and the front panel will come off.
Posted on Aug 18, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool AWM 1003 Washer - Bellows Seal
The following link gives you step-by-step instructions on how to replace the bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope this helps you. Let me know if you have questions or require additional assistance.
Posted on Sep 14, 2008
Replaced bellow now washer beeps and won't start
door switch may need adjusted to make up for the thicker bellows
Sep 25, 2015 | Whirlpool Washing Machines
Tip
Purchased my Whirlpool front loader 4/2004, we are on our 7th bellow, new inner...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on Feb 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer leaks. It is not the
The following link explains how to determine where a leak may be coming from in a Whirlpool Duet:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In many cases, the rubber bellow (door seal) is the source of the leak and will need to be replaced. If the bellow is ripped or torn the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
NOTE: THe bellow does wear out from time to time and will need to be replaced. However, using too much detergent, the wrong type of detergent, or loading the washer excessively can contribute to premature wear and tear and deterioration.
If you have any questions, or are having problems determining where the source of where your leak may be coming from , please post back and let me know. I hope this helps you.
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace bellow on machine
my dyer shows ad on my dyer what does this code mean?
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The following link explains how to replace a door bellow:
Another method involves removing the washer top panel and working down through the top of the washer. The method I have described, offers the best open access, however. If you have questions along the way, please let me know. I hope you find this informaiton helpful.
May 11, 2009 | Whirlpool GHW9200L Front Load Washer
Whirlpool Duet Washer GHW9100LW2 Bellow keeps on ripping
looks like it was a hair clip in my washer that did this :(
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Reinstalling whirlpool front load washer bellow
The easiest way to replace the bellows seal is remove the complete front panel.
This will really help: Duet front load washer repair manual
www.RepairClinic.com
Feb 03, 2009 | Whirlpool Washing Machines
Sep 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 43142 Front Load Washer Logo
247 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
