Question about Whirlpool 3362624 Washer Control Timer Knob
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried to remove the knob by pressing in the knob and rotating it counter-clockwise. The knob just freely rotate and would not screw off. Is the knob broken? How could I replace the timer knob? Thank you for your assistance.
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Posted on Jul 29, 2011
Our kenmore 80 series (110.27812692) pooped out on us,... the motor and water pump needed replaced, so we bought a used kenmore 70 series (110.82872820) from a friend,... it works fine, but the control...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer(s):
http://www.searspartsdirect.com/partsdirect/index.action
Enter the model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Check the part numbers for both machines in the "Console" section.
Also see the following Whirl[pool Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Whirlpool top load, washers use one of two different timers. Depending on the timer the knob comes off differently.
For most, by holding the back of the timer shaft with a thin needle nosed pliers, the knob unscrews.
Sep 13, 2010 | Kenmore Washing Machines
Cannot set Control dial for wash cycle. Knob will not move indicator dial. Rotating without engaging indicator. Thanks
Pull the center knob strait off. I suspect the center shaft of the knob is broken. If it is order a new knob but before replacing it make sure the shaft on the timer does not have a metal sleeve from the knob remaining on the timer shaft. Temporarily you can try to use needle nose pliers to turn the shaft to see if the washer works.
Aug 21, 2010 | Washing Machines
Removeing timer switch knob
First, see the Sears parts site for your washer:
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
The knob screws onto a medal shaft that goes through the timer.
Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
Then you simply have to disconnect the timer.
The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
Jun 08, 2010 | Kenmore 24032\24036 Top Load Washer
Instructions for installing timer part number 8541110 for Kenmore elite wash machine.....
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Then see the following for how to release the console for access to the timer.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5216f244d51176ce1069bbf148b14335
Then see the following Whirlpool / Kenmore Service Manual for top load, direct drive washers. It has troubleshooting and testing procedures as well as a description of the TWO types of timers. Each has different procedures for replacing them.
If yours is the metal type, the procedures call for unscrewing the timer knob before it can re removed.
You may need to use a thin needle nose pliers to hold the shaft on the back side of the timer in order to unscrew the knob.
May 08, 2010 | Kenmore 24032\24036 Top Load Washer
The dial to select wash cycle (GE top load washer) seems loose. It is difficult to turn, as if something is not engaging. Any suggestions?
The knob wears out and won't grab. It is easy enough to replace if you know the trick. Take pair of tweezers and remove the clip behind the knob, just push on the replacement knob and oil the timer then move the timer around several times to help the shaft turn easier.b8e8a25.jpg
May 02, 2010 | GE WBSR3140DW Top Load Washer
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
What are the possible problems if the control knob seems not functioning?
It sounds as if the the shaft on the timer assembly is either sheered or the knob has lost its grip. Pull off the knob and check it for tightness of fit when refitted...You may just need a new knob!
Oct 25, 2009 | Whirlpool LTE6234D Top Load Stacked...
Timer control won't ingage. Took timer knob off and it seems to be ok but it will not ingage with the teeth on the part below it. It just goes around. Disk that has the pointer on it seems to fit properly...
A pin thru the timer shaft can break, or the plastic teeth it engages in can be stripped.
It is not difficult to repair if you have the parts, but you can only get these from another timer- maker will not supply parts.
To take timer apart.
Take it out of the machine.
You will see two twisted metal tabs on the back and one on the front.
Carefully straighten the tabs and the timer will come apart as FRONT, BACK, CAM ROTOR
Gently remove the shaft and you will see what part has failed.-- replace.
Be very careful with reassembly not to bend the contact fingers.
Sep 12, 2009 | GE Washing Machines
Whirlpool 3362624 Washer Control Timer Knob Logo
351 people viewed this question
Top Whirlpool Hardware & Accessories Experts
Joseph Mueller
Joseph Mueller
Bill Boyd
Are you a Whirlpool Hardware and Accessory Expert? Answer questions, earn points and help others
