Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Both dvd and cable tv are suddenly in black and white with poor picture quality, but perfect picture via normal arial. have changed scart leads but no difference. could it be a problem with the scart sockets on the back of tv set? thanks!!
  • Scott Frye
    Scott Frye Oct 09, 2010
    What is the source for the SCART signal?
  • 55 Answers
Sounds like the main signal board went poof
Posted on Oct 09, 2010
Phillips DVD recorder connection issue?
SCART is designed to carry analogue standard definition content. So if the input signal is high def. it will distort.
Jun 09, 2014 | Philips Televison & Video
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
When I switch on my dvd even the set up page is in black and white. Originally I was getting no picture so I made sure everything was plugged in. Then I got the black and white.
Check the scart cable , try connecting it to another scart socket on the tv. I would even change the scart lead to make sure its ok. I have had loads of similar problems like that caused by scart leads faulty or connected to the wrong socket.
pete.
Nov 27, 2010 | Philips DVDR3380/05 DVD Recorder
I would like to know how to connect a dvd player through my samsung vcr the inputs in the back i am not familiar with there are two sets of yellow white and red connections with one side for output and...
Connect from dvd OUT to vcr IN
The yellow connecter is video, red is right audio and white is left audio.
You can purchase converter leads (scart to phono(the red/white/yellow connecters) or many other combinations) if needed.
If you have scart connections ( a block of 21 pins) then use that if possible as it will give a better picture.
Connect the dvd out to vcr in and vcr out to the tv in.
NOTE. if you connect this way you will find that the copyright protection will make viewing dvds quite poor quality and may even be black and white or even the picture may "roll"
You may want to buy a scart block to connect more scarts to the tv then it has, also you can get these with different connections.
Dec 30, 2009 | Samsung VR8607 VHS VCR
Just bought a toshiba 42av635db and the picture is very grainy, any ideas?
Dear shaunamlynch,
Try to adjust your display properties and choose the color depth mode by sliding it up or down and choose the best color mode (Better to set the on the TRUE COLOR (Highest)). Apply and reboot!
Good Luck!
Best Regards,
bionic23
Nov 04, 2009 | Toshiba Advanced Port Replicator III...
Poor picture quality on cable input
Try swapping some cables around, like the skart lead from the dvd(if scart) for the cable one, if the picture problem swaps with the lead then thats the problem. If it doesn't try settings on the cable and tv, if the cable is sending nvbs signals and the tv is set to pal then this can also occur.
Jun 30, 2009 | Dell W2306C 23 in. HD-Ready LCD Television
Wiring diagram for sony kdl-23s2010
i can tell you the best way but i need to know what your using ie scart leads things like that also tell me how many scart sockets in telly and in dvd and sky and vcr after you give me this info il tell you what needs pluggging into what
basing it on your telly has 2 scart if not let me know ok
1. dvd to telly via scart lead
2. then sky to vcr via scart doing it this way allows you to record sky using av channel on vcr
3. vcr to telly via scart lead
then if you want your video to record normal telly channels you need to use normal arial leads in this order
1. from arial to vcr then from vcr to telly doin this allows you to record the channels you get through the arial like 1 2 3 4 5 also this way when you choose 1 or 2 or 3 on video it will record that channel allowing you to watch whatever on sky whilst recording normal telly
If your telly only has one scart socket in the back then you need to buy a scart adaptor that converts one scart socket into 2 or even
let me know if you understand what im telling you or if you need further help ok just let me know im going out for 2 hours but will check your reply then so hope you dont mind waiting if you need help ok
Feb 18, 2008 | Televison & Video
No channels
are you plugging it into the actuall cable or is it an arial socket if it is the cable you need a cable box as you change the channels on this if it is the arial then it should have a self scan mode in the setup you wont get cable channels without a cable box because they opperate at different frequency and the newer tellt are made not to pick up these frequency so you have to purchase the cable box this should be plugged into your telly via a scart lead then you change the channels on the cable box the only channel maybe it is different as i live in the uk sorry i couldnt bbe any more help
Oct 31, 2007 | Proscan PS32600 32" TV
Samsung LE32R87B
The fact that this is on all inputs suggests that teh screen is faulty, i would bring it back and get it replaced.
May 09, 2007 | Samsung LN-R409D 40 in. LCD Television
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
105 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
