Question about Coby MP-C582 MP3 Player
Coby mp3 clip How do you charge it? I have tried charging with it on and off so not sure why the light won't turn on when I want to play it. It lights up when charging but I can't hear any of the songs. Would I be able to listen to an audio book on here if it is within the 1GB? Thanks
SOURCE: Charging the coby clip 1gb m582 mp3 player
MINE HAS NO SWITCHS JUST THE USB PORT AND I CANT GET IT TO CHARGE
Posted on May 27, 2008
tech48
  • 624 Answers
SOURCE: Coby MP-C582 Will not turn on
This is clearly a defective unit, since you just purchased it you should take it right back to the place you got it from and get a replacement for it. If you attempt any type of repair yourself, you will void the warranty. It should have at least a 30 to 90 day warranty, some even have a 1 year warranty.
The actual problem you have with it is not an easy one to diagnose without having it in my possession to troubleshoot it with the proper test equipment. There can be many reasons it will not turn on and can only be identified with any certainty by troubleshooting it on a test bench.
If it doesn't have a power button, then it should turn on by just pressing the play button. You should check with the owners manual you got with it when you bought it. It will explain all the features and even a couple of troubleshooting tips if it is not working normally.
Uploading a song before charging will not cause it to fail as you have described, or fail in any other way. It should not make any difference at all.
Posted on Sep 20, 2008
SOURCE: sansa clip mp3 1GB problems
I've synchronize several songs, but the player only playback certain songs and the other songs give me the following message when I try to play "synchronize to continue your music subscription"
Can anyone help??????
Posted on Oct 06, 2008
SOURCE: Can I download WMA audio book files onto by Coby MP3 player?
copy and paste the files
Posted on Feb 03, 2009
snow_cedar28
  • 12 Answers
the manual says something about turning the player on when inserted into the usb port so it  can charge
Posted on Mar 10, 2009
Why won't my mp3 coby player won't charge
Your coby is not charging anymore..The battery probably needs to be replaced with a new one..Please check your connection when you charge it..There should be an icon that shows your battery is charging. If it does so that means your coby is charging but your battery cant store the energy anymore.
Feb 19, 2012 | Coby MP-610 MP3 Player
It wont turn on.
make sure that you charge it for twelve hours consistantly....once it is charge after you can hold down on the power button and the light comes on- use a paper clip and reset the player it should now work....
I had to work with mine for three days to get this working- biggest thing is the charge solid red light and the reset button (also making sure you have music already on it of course-)
hope this helps!
Dec 12, 2009 | Coby MP-C582 MP3 Player
Coby MP550 MP3 player problem
1. Make sure the hold switch is in the "off" position.
2. If the light comes on but your media doesn't play, it could be that you've load files which have DRM applied. The player does not support DRM, and thus can't play the files.Try playing a file that you are 100% certain does not have DRM applied.
3. If the light does not come on, the battery is fried (if LiPo batteries discharge past a certain point, they have a tendency not to recharge, no matter how long you leave it on charge). Return the player to the store where you purchased it.
Sep 17, 2008 | Coby MP550 MP3 Player
Coby MP-C7095 Won't turn on
On my Colby player there is a small reset hole in the back. Mine has sometimes just stopped playing and shuts off. If you use a small wire (paperclip works well) push it in and reset it.
Mar 12, 2008 | Coby MP-C7085 MP3 Player
These players are notorious for battery problems. Charge it all night and you just might get 30 minutes of use out of it before the battery dies. Make sure the slider switch next to the power button on top isn't in the "lock" position as the unit will not power up if it is. I recommend getting a 12 volt car charging plug for it and getting real aquainted with the tiny reset button on the battery side of it. You can get a plug for about $6 that will charge it through the usb cable that came with the player.
Feb 27, 2008 | Coby MP-C7085 MP3 Player
Coby mp3 clip
try hooking it up to a computer. aparently it make's it charge. i don't know if it will work i had the same problem.
Jan 13, 2008 | Coby MP-C582 MP3 Player
Jan 06, 2008 | Coby MP-C582 MP3 Player
Player is not turning on
Sometimes I must hold the play button down for over 7 seconds on my unit to get it to turn on. See also the answer to the question on properly charging the unit; i.e, have the slide switch in the "off" position.
If you are using a USB hub to charge the mp3 player then the hub must be powered.
Jan 02, 2008 | Coby MP-C582 MP3 Player
Check on the side of the player and make sure it is not locked that was why ours would not turn on. Once I unlocked it worked fine
Dec 24, 2007 | Coby MP-C582 MP3 Player
Coby MP-C582 MP3 Player Logo
64 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
