Question about Kenmore Elite 45986 Front Load Washer
My frontloading kenmore elite washer suddenly got all the prprogrammed wash cylces mixed/messed up the ultrahand wash cycle which was once 35 minutes now shows 1:10 the normal wash cylce is now for 11 minutes, previsouly 1:05, the whitest white cyle shows blank screen...what happened/ did something electronically fail or do i somehow need to reprogram it?
  • 2 more comments
  • drbessie Oct 09, 2010
    What do yo mean by reset the timer? My understanding is that the preprogrammed cylecs cannot be changed and there is no way to alter them. How do you reprogram the preset wash cycles
    " check the timer setup and try resetting time and reprogram " ---what does this mean.
    there is not way to rese the time and "reprogram" I have never programmed this washer
    it was preprogrammed from the factory.....
    This machine has no way to program it
    It was preprogrammed with about 8 or so wash cycles
    somehow all the was cycles have gotten messed up
    the other expert thinks I should reset it? He doesn't say how...the machine has not way to "reset" it
  • drbessie Oct 10, 2010
    holding down the drain/spin button for 10 seconds does not reset the controls as suggeste by the previos expert...it simply locks and unlocks the control to prevent a child from pressing the control.
    how then do you reprogram the preprogrammed wash cycles?? They are all messed up.
    President:
  • 1,554 Answers
The only way to "reset" the machine is by unplugging it for an hour or so and the preprogrammed cycles can never be reprogrammed. The problem here is likely with the User Interface (UI) board itself. But a problem in the Motor Control Unit (MCU) can interfere with the communication between the Central Control Unit (CCU) and the UI. Disconnect power then remove the top panel to access the CCU and disconnect the harnesses from terminals MI3 and MS2. These harnesses are for MCU communication and power respectively.
Reconnect power then run the machine with each of the cycles. Replace the MCU if the problem doesn't appear with the MCU disconnected. Replace the UI if the problem still exists.
Posted on Oct 10, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To reset the controls press and hold the DRAIN/SPIN button for 10-15 seconds, after doing this if the issue is still not resolved then the electronic control should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 09, 2010
  • 2,272 Answers
First of all try resetting the machine by unplugging it for a minute from main power outlet and then plug back in and ON the machine and check.if everything goes back to normal or not.
If the problem still exists then check the timer setup and try resetting time and reprogram it. if it still messes up then replace the timer.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite frontloader and when im washing it stops in the middle of the cycle and displeys F20 what does that mean
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first.
Nov 17, 2009 | Kenmore Elite 45986 Front Load Washer
I am repeatedly getting an F20 error on my Kenmore HE5t washer. It seams the the spin cylce before the final rinse is the sticking point. I have to unplug, restart and finish the cycle with final rinsie...
Oct 12, 2009 | Kenmore Elite HE5t Washer
Kenmore Elite Top Load..Rinse water keeps running in Spin Cycle. Clothes are soaking wet when spin cylce is complete
the fill valve is an electric magnet valve and sounds like it is stuck unplug machine disconnect water lines plug in and when u turn on does it click, if yes then unplug try to slide a long qtip in and if it goes in replace valve
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore frontloader washing machine making roaring
Your rear bearing is bad. Check warranty to see if rear tub is still covered.
Mar 08, 2009 | Kenmore 44102 Front Load Washer
I have an elite he2 plus frontloading kenmore washing machine and no water is coming in the washer.... the temperature has been low here, but i have taken every precaution to ensure that my pipes aren't...
Only if your temperature in your area goes below 35 degreesF.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 16, 2009 | Kenmore 46462 Front Load Washer
New Kenmore Elite Front Loader will not get past 'Sud' cycle,
Hello wheeljc; I had the same problem when I purchased my Kenmore Elite in 2006. I have a HE4t front load. It's possible that you're using to much detergent, if you're using HE liquid it only requires a small amount and does a very good job.
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Jan 21, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
47 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
