Question about Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter
When I plug the headset into the charger it blinks red and blue and won't hold a charge. Is there anything I can do to fix this?
  • Insignia Master
  • 17,130 Answers
You might have to check the adapter for charging voltage , if faulty you will need to check the wires, the adapter, if faulty replace.
If the adapter is fine and giving the right voltage then the battery within the unit is fault. you will need to open and check to confirm and replace.
Posted on Oct 09, 2010
My HBS-900 headsets have a blinking red and blue light that blinks when it's on and off, it won't pair with anything, and when I put it on charge it blinks red and blue
Usually this means there may be too many Bluetooth devices in range to connect to and cannot connect so the blue and red flashing lights indicate an error. A second possibility is that the device is broken. This might sound strange but sometimes several sharp firm raps to the side with the charger port and lights along with a few power cycles often snaps it out of error and back into operation. Good luck.
Dec 28, 2016 | Radio Communications
Will not turn on unless plugged up to charger
Your built-in rechargeable batteries are perhaps defective and do not hold charge.
Hope yours is not a clone.
Mar 28, 2016 | LG Electronics HBS 800 Bluetooth Headset
Why My Nokia BH 505 Stays Blue When Charging?
Do an Hard reset. Plug charger into the headset, press and hold power button and plug the charger into AC, light indicator will change after a while from red to green/blue.
Feb 14, 2014 | Nokia BH505 Bluetooth Stereo Headset
BLINKING RED LIGHT WHEN TRYING TO CHARGE UNIT
I fixed this problem by connect it on the charger,hold +and - keys together for 10 seconds,it started to charge and work well.
Jan 21, 2014 | Motorola Mobility H730 Bluetooth Headset
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
My plantronics voyager pro will not charge turn on or anything. do you know the peoblem?
I have seen on some Plantronics Bluetooth headsets that you can perform a system reset by doing the following, It might help but not sure.
Instructions:
While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Good luck from Headsets Direct!
Jun 18, 2011 | Plantronics Voyager PRO Bluetooth Headset
My motorola n136 headset will not charge. This is my second headset with both doing the same thing. When pluged in to wall charger the blue light comes on but it is not charging. What am i doing wrong?
I dropped my 4-5 month old Motorola N136 bluetooth under my couch while activated. Took me a week to get it out, and now it will not take a charge. All I get is the red light blinking over and over when plugged into my charger. Any ideas? lotsofstufflv@gmail.com
Jan 03, 2011 | Motorola Mobility H270 Bluetooth Headset
Will not power on. When plugged in, I can get a blue or red light, but no power indicator when not plugged into the charger
Don't know how helpful this is but if you are using the Altec Lansing backbeat 903, I had a similar problem. I couldn't get the headset to power on or charge(no blue or red lights that blink or stay on), so what I had to do was a reset on the bluetooth/headset. You simply press and hold the power button, then while holding the power button plug in the charger. Of course the chager was plugged into the wall.
Aug 04, 2010 | Altec Lansing BackBeat Plus Mobile ...
Motorola H550 bluetooth headset
i turned it back intno the store got a refund and went to a different headset. sorry to bother you but i think it had to do with the battery in the headset
Feb 24, 2008 | Motorola Mobility H500 Wireless Headset
Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Logo
142 people viewed this question
Top Insignia Radio Communications Experts
Skyken
Level 1 Expert
woodzowl307
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
