Question about LG LFX21980ST Stainless Steel Bottom Freezer French Door Refrigerator
LG Refrigerator, LFX21980ST. The refrigerator runs constantly. We unplugged it for a couple of minutes. That didn't help. Ice maker is stuck on "Crushed" and we want "Cubed." We emptied the bin and let it clean out (melt and dry). Reset the digital panel, reset the interior panel to large cube. Turned ice maker on and off several times.
SOURCE: Cubed versus Crushed Ice Cubes
I have the exact same problem with my LG SXS refrigerator.
Posted on Aug 19, 2008
  • 489 Answers
SOURCE: Ice maker will only dispense crushed ice
You may have a broken solenoid inside the motor assembly.  The solenoid controls the arm for cubed or crushed ice.  The only way to tell is remove the ice dispenser motor assembly and look at the solenoid.  If the solenoid is broken, replace it and everything should be ok.
Posted on Aug 20, 2008
jeffbvegas1
  • 520 Answers
SOURCE: LG ice maker only dispenses crushed ice not whole cubes
Very problematic issue with this model .Try unplugging and plugging the fridgerator which resets the board.The board is located on top under a removeable panel where the power cord enters....there is a reset/diagnostic button on the board itself.Contact LGUSA.com for any possible warranty and complain like crazy to avoid spending $300 on this board which can be purchased from andrewselectronics.com who is a factory authorized parts provider.Keeping that ice maker going will make you pull your hair out which is unfortuante for such a stylish and expensive fridge.good luck
Posted on Jun 28, 2009
  • 112 Answers
SOURCE: my ice machine makes ice but will not give me out
The ice bucket is not installed correctly.
On the back of the ice bucket is a round bar. This round bar has to be lifted to open a door to allow the ice to bypass the crusher assy.
You will need to remove the ice bucket and reinstall it so that this bar is inside of the white plastic assy. This square white plastic assy needs to down (you may have to put your finger in it to pull it down) so the bar can go inside of it. This plastic assy goes up when cubed ice is to be dispensed.
Good Luck.
Posted on Jul 25, 2010
  • 489 Answers
SOURCE: Bottom freezer not keeping bread or ice cream
You may have a defrost problem that needs a technician to resolve for you.
Posted on Jun 16, 2011
LG LFC21760ST Beeping Constantly again. Last time it cost me a fortune to replace the computer board. Isn't there a cheaper way to stop the sound?
I would suggest starting with the easiest troubleshooting tip first. Try unplugging it for 10 minutes and plugging it back in. Most (modern) appliances will reset to factory defaults when they are unplugged for a few minutes.
May 29, 2014 | LG LFC23760SB Three Door French Door...
Ice maker fan running constantly
There are 3 fans on your refrigerator how are you sure that it's your ice fan that is running?
Nov 08, 2013 | LG LFX23961SW Bottom Freezer French Door...
Unit turns on and starts to cool. Then runs for about 5 minutes and turns off. Unplug unit and plug back in and it repeats the problem. Will stay running.
It can be issue with temp sensor getting overheated or compressor getting overheated or issue with compressor relay or capacitor.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Marvel 61HK Commercial Beverage Dispenser
I have a Frigidaire GSI 26, ffor the last couple of days it has been making a buzzing sound that lasts about thirty seconds to a minute, today the freezer quit working. the compressor is hot, as is th
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
No water to icemaker, but through the door water is working. Ice maker itself is ok.
This is most likely cause because some part of the ice maker/distribution mechanism is broken. If at all possible, remove everything from the fridge and freezer and allow the freezer to thaw. If that is not possible, you could try and remove just the ice maker to thaw it or try and thaw it while it is still in the freezer. I hope this helps and have a nice day!
May 04, 2011 | LG LFX21980ST Stainless Steel Bottom...
ICE MAKER NOT WORKING LBC22518WW (LG REFRIGERATION)
Hello, just like your problem, our ice maker just stopped making ice. We solved the problem by unplugging the refrigerator for about 2 hours leaving the freezer door open.
It started making ice a few minutes after plugging it back in. Obviously the line that supplies the water had frozen and this allowed it to un-freeze.
We didn't remove any of the frozen items in the freezer, at the two hour mark, everything in the freezer was still mostly frozen.
Thanks
Jul 13, 2010 | LG LBC22518 Bottom Freezer Refrigerator
I am interested in the lg bottom freezer french door refrigerator but my current refrigerator does not have an ice maker and is not near a water source, since the ice makers are standard on these...
You will want to make sure it stays in the off position or it will constantly cycle thinking it is making ice and burn out the water valve coil. If you are definitely not going to hook it up removing the ice maker will accomplish the same thing and give you a few more inches of storage.
Eric
Jun 08, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice.  If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
May 16, 2008 | LG LFC25760 French Door Refrigerator
LG LFX21980ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
87 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
