I have a Sears Kenmore Advantage Laundry washer Model 110.92480200, stock 24801 that does not adequately agitate and does not spin the water out of the clothes. What could possibly be the problem?
  • 172 Answers
SOURCE: i have a sears kenmore
If the entire agitator is not moving you will have to replace it. If the top is not working properly, you will need the 4 little gears inside the top calle d agitator dogs. The set of four cost about $8.00 and are available at any appliance parts store. To get to the agitator dogs you will remove your fabric softner dispenceer, if you have one. Then pop off the top lid of the agitator. It will have a small spot to insert a screwdriver and pop it off. Then reach down inside the agitator and pull out the next little cover. Be carefull not to loose the seal. Then you will need to unscrew the bolt that you see in the bottom. Once you have done that the agitator will lift off. The top will not pop off the bottom and you will be able to see the four little tear shaped gears called DOGS. I love the name. You should be able to install the new ones fairly easily and then just line the top of tha agitator up with the bottom and push it back down into place. If you look down inside the agitator you will see two little clips that you will need to line up. It is really an easy repair. Let me know if you have any other questions.I hope this will FixYa. Please rate me when you can. Mike
Posted on Sep 24, 2008
  • 958 Answers
SOURCE: Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
  • 7 Answers
SOURCE: washer doesn,t spin
two possibles here, if the drain pump is clogged and therefore the unit will not go into a spin. After pumping, it will error out and just shut off. If the pump is ok, then the motor control unit has failed.
Posted on Oct 28, 2008
  • 115 Answers
SOURCE: Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Posted on Dec 31, 2008
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore 20422 leaves water and clothes soaked after spin cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Initial thoughts point to one of two places.
1. It's possible that your pump and/or hoses are clogged.
2. It is also possible that the "Motor coupler" between the motor and transmission is worn and cannot provide full power to the tub when agitating.
See the following illustrated descriptions of how to access the pump and motor coupler.
If either is bad or worn, they aren't all that expensive.
I doubt that the problem is the motor since the machine will agitate and spin.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=1c39a06ff50bcc5c8439ed37e02f402a
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Jan 06, 2010 | Kenmore 22422 Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Agitator spins in one direction
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you have a two piece agitator, the top section is only supposed to move one way.
See the section in the Sears site for the agitator dogs.
If the lower section only turns in one direction, the problem is likely in the transmission.
See the following Whirlpool Service Manual for top load direct drive washers.
Nov 07, 2009 | Kenmore 24902 Top Load Washer
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
Kenmore model 110 will not agitate or spin............ it will fill with water and drain ........but will not spin or agitate.............. you can hear the motor runniing
You have a broken drive coupler. This is a very common part that fails. This is the piece of rubber between the motor and the transmission. Lean the machine back and reach behind the motor and you will be able to feel the rubber coupler wiggle. This is supposed to be tight. Another sign of it being bad is rubber on the floor under the machine. I replace at least 5 a week. This is your problem for sure. The part number is 285753. You can order this at sears.com or your local parts store should have it in stock.
Nov 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer humms and smells horrible....
You have a bad motor. ( very common) If you take your model number to a local used parts store you may be able to find a good used motor for cheap. If no luck finding a used one, Order it from sears. (the motor is deffinately your problem, I replace them all the time.)
Nov 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 90 - Model 20990902
I don't see that model # listed. Please recheck and get back to us
Feb 07, 2008 | Washing Machines
Kenmore 94802 - Goes through all cycles.. Doesn't stop after last spin cycle.
I hate to say it, but it sure sounds like a timer problem. There are contacts inside that move and switch items no matter what setting its in. Its a possibilty that the power contact is stuck closed and when you manually turn it off it breaks contact. The job to replace is really not that hard, remove console (unplug unit first), mark your wires, then just replace. The part though is a touch expensive (131789200 Sears Part Number). Probably would be a little cheaper than buying a new unit I guess. Let me know if you need any further information. Jim
Nov 04, 2007 | Kenmore 94802 Front Load Stacked Washer /...
Washing Machines Logo
Top Washing Machines Experts
