Question about LG 52LG60 52 in. HDTV LCD TV
HOW TO RESET PARENTAL CONTROL PASSWORD FOR 52LG60 SCARLET
Remove parental controls PS2 brick
enter 7444 in the parental controlls password box to reset the password and controll levels
Mar 07, 2014 | Sony PlayStation 2 (PS2) Console
My son blocked everyone out of the tv with parental control. He can't remember the password he used and I can't get the reset to do anything. How can I fix this?
If you have reset the TV back to factory settings, you can use the factory unlock code, which is 0000.
To Reset the TV:
  1. Press the MENU button on the remote control to display the Main menu, and select SETUP.
  2. Highlight Reset Default, and press the OK button.
To Remove the Parental Control Block:
  2. Highlight Parental, and press the OK button.
  3. To use the Parental function, must enter a four-digit password. The factory password is 0000.
  4. Select Program Block, and press OK to display the Program Block menu.
  5. You can remove the parental control in this section.
May 25, 2011 | Polaroid TLA-01911C TV
How to reset password on playstation 2
Hi Jessica
There are two methods to reset the Parental Control on a PlayStation 2, the Quick Method and the Easy Method.
The Quick Method to Reset Parental Control
  • Power on the PS2
  • Press the Reset button
  • Inset an R-rated and wait until the board comes up telling you that Parental Control is on
  • Hit the Select button
  • At the enter password prompt, hit the Select button
  • At the Delete password prompt, enter in your password
  • Hit the X button
If you do not know the Parental Control password on your Ps2, try the known defaults of 1111 and 7444.
The Easy Method to Reset Parental Control
  • Unplug the PS2
  • Wait approximately 72 hours
Hope this helps :)
Mar 20, 2011 | Video Game Consoles & Games
Reset parental control password
I can help you unlock your Mitsubishi HDTV V-Chip parental lock.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Sep 26, 2009 | Quasar SP-2722 27" TV
Lost old password to parental control. How to reset?
lost old password to parental control. How to reset?"
Apr 25, 2009 | Daewoo DTQ-27S5FC 27" TV
Forgot V chip password on Insignia IS-TVDVD20A
i have an insignia hdtv and the manual says if you forgot the password, enter in 3448 in the password box to reset, it might be the same for yours, good luck
Jan 04, 2009 | Insignia IS 20" TV040919 TV
How do you reset forgotten parental control password?
try 3308 if not read the instruction manual or telephone them for support
Jan 04, 2009 | RCA HD52W59 HDTV Projection Television
Remove Parental Control Password
I have forgotten the password for my parental control/content adviser window. Can you help me either remove it or change it without knowing the existing password. Thank you!!
Sep 05, 2008 | Curtis CM13102 13" TV
Parental control
Here is the procedure to reset the parental lock code:
  1. From the XBOX dashboard screen, go to settings and then parental control.
  2. When prompted for the password, perform the following sequence using the XBOX controller: X, Y, Left Trigger, X.
  3. Enter in a new password, or disable parental control entirely.
fixya!
Feb 07, 2008 | Microsoft Xbox Console
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
Nov 29, 2007 | JVC AV-36260 TV
LG 52LG60 52 in. HDTV LCD TV Logo
66 people viewed this question
Computer Repairing
Computer Repairing
