Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
Dell E510 desktop
From last week, my system is rebooting itself over and over again. Like it is stuck in a endless loop. I am running Windows XP SP 2.0.
Thanks,
Asif Kidwai
3179850746
  • 2 more comments
  • hanniya May 30, 2008
    kubis,
    I have already tried that. I even format the entire hard drive and tried to re-install entire OS on it. But it is still rebooting over and over again. Any other ideas.
    Thanks,
    Asif
    Any other ideas. Since, I have read several blogs where it is also saying it could be Poswer Supply issue. Which I dont understand how.
    Regards,
    Asif
    Wiz,
    I think and hope you are right. Since I have tried everything which I knew or was suggested to me. That is the only thing left now. I am going to buy a new Power Supply and see if that would help the cause. But I do have one question, I can hit F8 and it will take me to the system setting and it also installs all the files and seems to me install entire OS every time i install. So If this is power supply issue, why is it installing the OS but only reboots over and over again once it is done installing everything. i am just curious.
    Thanks,
    Asif
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    you'll most likely need to re install the operating system software.
    Genius:
  • 3,587 Answers
The power supply is a possibility. If it's cycling, that would appear to the uP and memory as a power interruption. Only way to find out is use a power supply tester(doing it with an ohm meter if fine, but you'll need to test it under loaded conditions).
Posted on May 30, 2008
  • Patrick Michaels
    Patrick Michaels May 30, 2008
    the reboot, is actually the cmos power recycling ..and it never really gets tracked. Happens during power fluctuations, by the way too.
  • 10,594 Answers
If your PC is more then 2-3 years old, please replace its power supply box and install new power supply. Mostly power supply comes with computer cabinet.
Technically, power supply voltages are not accurate or correct required to PC. Thats why PC boot n reboot again n again. Thats all know as an electronics tecnician.
  • Shahid Electronics
    Shahid Electronics May 30, 2008
    In my point of view, hitting f8, PC shows screen in text mode but after installation of OS, PC runs and use all its resources, so it requires more voltages/ current.
    You can verify my idea by measuring voltages through Digital Voltmeter. +5 volt supply is very important in desktop pc. It must be +5 volt exactly. If it decreas and become 4.8 or some what like that, pc wont run properly and can be shutdown any time. I been faced this situation.
    Problem Solver:
  • 15 Answers
Hi Asif,
Did you install there something new on it? Maybe could help to push the F8 key after POST (just after the DELL logo disappeared and before Windows logo would appear) and choose to start with last configuration which worked. If this doesn't help then after F8 choose to start in Safe Mode and uninstall the failing application after you log into Windows.
Acer aspire is stuck in repair loop
From cold start, try F8 and if granted a choice to load as normal, choose that. If normal load succeeds, after Windows finishes loading, restart the computer. This should store a normal registry, i. e. one that does not direct you into a loop. I probably would subsequently use an sfc command but to avoid describing that I would simply suggest downloading Glary Utilities and going to the system repair menu item that will replace/repair system files. That takes a long time but then you know your system files are not corrupted. And I would reboot again, then.
But for you, here is a link that describes how to free yourself out of the endless loop if the above is of no help:
Windows 7 help and support forum
Sep 05, 2017 | Acer Computers & Internet
Computer will not power up
When Windows is updating you basically need to wait for it to finish before you power down or you will find yourself in that endless loop of updating. You may need to reboot into safe mode by pressing F8 as windows is staring up, then let it run updates and again reboot.
Sep 06, 2014 | eMachines EZ1601-01 All-in-one PC 18.5'...
Downloaded Windows XP Update SP 3. Now system
When you installed SP3 it was also placed into Add/Remove programs, (In control panel). Boot the system and enter safe mode. Uninstall SP3.
See also Microsofts instructions on how to remove SP3; http://support.microsoft.com/kb/950249
Did you find this helpful
Mike
May 21, 2010 | Microsoft Windows XP Home Edition
A friend held down the pwr button after a windows update to restart the PC instead of doing a shutdown (he thought that's the way to do a restart) and now it BSODs on normal XP start and locks up mid...
The recovery console can only be used if you have a recovery disk that was supplied or if you made one.
This is not a repair option that will just repair the PC.
The admin password is the password you set, windows does not set any passwords, so if you did not set a password then just hit enter, but as I said you need the recovery disk.
If you can not get into safe mode or the PC does not have a option to enter system restore, which could be F8, then there are a few things you can try.
You can try the last known good configuration,
you can try the repair boot.
.Boot with XP CD or 6 floppy boot disk set. 2. Press R to load the Recovery Console.
3. Type bootcfg.
4. This should fix any boot.ini errors causing setup not to see the XP OS
install.
Your best bet is if you have the windows disk,is to reinstall windows, but you need to go to the maker of the computer or you need to go to the motherboard and get all the drivers for your system.
What happened was, when windows installs updates it is writing to the system, and it warns you not to shut down, and this can take up two a few hours, it could have been updating a service pack. The system is stuck in writing and you will have better luck just reinstalling when using windows xp.
Vista is eaiser to repair then xp.
Feb 11, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Endless chkdsk /r loop
Sounds like you have a seriously corrupt hard drive. I am afraid the only way to fix this is to replace the hard drive.
Good Luck!
JL
Dec 30, 2009 | Dell Dimension 8400 PC Desktop
Can't start Windows, Blue Screen gets in the way.
can you press the function key that takes Windows to diagnostic mode - usually F8. You have to press this key very quickly after you power on.
This might help you understand where it is failing.
Hopefully you have a recovery CD with which to boot and test the hard drive for corruption.
You will need to setup the BIOS bootup sequence to go to CD first.
Dec 30, 2009 | Dell Dimension E510 PC Desktop
I have an Dell Dimension E510 running windows XP. I have 5.1 surround sound speakers that were working fine until recently. Only 2 speakers work; left and right. None of the others have sound. I have...
Reinstall the software for the sound system, this should redetect the speakers properly as 5.1 surround sound speakers.
If you do this and it still doesn't work then the speakers are bad and your sound system would need to be replaced.
Dec 01, 2009 | Dell Dimension E510 PC Desktop
The DVD player on my Dell E510 plays DVDs but the sound crackles
Use Internet Explorer to download this file:
http://winhlp.com/tools/resetdma.vbs
Run it.
Reboot system.
Mar 20, 2009 | Dell Dimension E510 PC Desktop
Xp caught in loop when started
the Windows Operating system is corrupted.
what operating system are you running??
Windows VISTA or XP??
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
292 people viewed this question
Alun Cox
