Question about Dell Latitude D600 Notebook
Dual window xp
Persently system working on dual Window XP and I want system work only One Window XP. please give me instraction I want remove the one Window . Give me solution soonly.
    President:
  • 1,257 Answers
Before performing any operation, take the back up of boot.ini file in c: driver
Now use the dos bootable disk to format the partition in which your second copy of xp is installed let suppose d: drive,and after that when your windows xp start it will still show you both the copies of xp but select the one which is working and when you come to desktop .Go to Start > Run > type cmd and hit the enter key to start command prompt now use cd\ ,now you will come to c:\>..
Now type boot.ini. At this a text file which contains the details about the operating system will open ,delete the one which you have formatted .it will look like this
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /FASTDETECT
Was this solution helpful .Show your appreciation by rating it.
Posted on May 30, 2008
How to remove an operating system in a dual boot?
In Windows Xp, you can install two operating systems on the same hard disk of one computer.
Whether you have two copies of Windows Xp, or two different operating systems, then you end up with dual boot machine when you restart your Windows Xp computer.
Dual boot means, the system will give you a choice of two operating system. For example, if you have two Windows Xp copies A ans B, the prompt will offer you to choose A or B to boot from.
Also, dual boot machine can be used to have Windows Xp, and Linux O.S. installed on the same computer.
In the case where you have two windows Xp copies on the same hard disk, you will experience a slow performance in your system.
If you need to delete one Windows Xp copies, and leave only one, here is how you do it:
When you restart your system, and you get a choice of two operating systems, you should choose the one you want to keep installed on your machine.
Once the startup process is done, and your computer is ready to accept tasks to perform certain functions, you click on the "My Computer" icon and locate the hard disks, removable storage devices, and more.
In the hard disk box you should see two drive icons, like "C", "D". If the copy you installed later need to be cancelled, it must reside on the "D" part of the hard disk.
This is because the "C" is where you initial copy of the Windows Xp resides, and it is the one you want to keep installed as the only copy on your computer.
The way you should get rid of the "D" copy is to format the "D" part of the hard disk. just right click it, and choose format. This will delete the Windows Xp copy you don't need.
In summary, you can have two operating systems installed on your windows Xp machine, which will offer a choice of loading one of two operating systems.
The good thing is that you can cancel one, and leave the other, and your computer keeps running.
Feb 01, 2011 | Microsoft Windows XP Professional
Tip
How to make dual boot with window xp vista and windows 7
Dual booting Windows is the most challenging of the three options; however, making it work can be very rewarding. The process of creating a dual boot environment differs from Windows Vista to XP. Please follow the instructions according to which version of Windows you are currently using.
To run two operating systems on your computer, you will need to add a second partition. If you are not familiar with adding a partition, you can learn how in this section. Please note: each operating system will be able to see the other partition; thus, you can share files between them.
Dual Boot with window x and windows 7
You will need third party software to create a second partition for Windows 7; once you have created the partition, you can install Windows 7 on it.
Create a New Partition (Vista)
Click the Start button, right click Computer, and clickManage
In the left pane, click Disk Management
Now create a new partition by shrinking a previous volume so you can use the newly created space. Right click on the partition and clickShrink Volume.
Now right click the free space and click New Simple Volume…
Specify the volume size and click Next
Format the drive as NTFS, give it a label, and click Next
Power on your computer, insert the Windows 7 DVD, and restart your computer
Press the necessary key to initiate booting from your DVD (usually Esc or F12.)
Windows will now load the installation files.
Click Install now
Your computer will restart several times during the process as it configures itself and installs updates Be sure to leave the DVD in the drive and let Windows take care of itself.
Memory (RAM) – 1.25 GB required, 2 GB memory recommended.
Recommended 15 GB hard disk space per virtual Windows environment.
NB: Windows XP Mode is only available in Windows 7 Enterprise, Windows 7 Professional, and Windows 7 Ultimate.
on May 11, 2010 | Computers & Internet
I have a dual boot drive. C has windowds 7 and d has windows xp. Windows 7 on C works fine. However I can't boot into Window XP. I get an error saying the process has been stopped in order to protect...
Hello.
Just some thoughts:
1. Your Windows XP install (image ?) may be corrupt. Reinstall or capture another image.
2. Try installing Windows XP on C: and Windows 7 on D: That way the boot files are left for the older version.
Hope this helps.
Jan 01, 2011 | Computers & Internet
Xp installation problem
the system doesn't accepts the lower version of windows if you are having the latest version than xp. for thi you must format the two OS softwares and first install lower version i.e., xp and then by dual booting you can also install vista or windows 7. then you can use both versions..
May 29, 2010 | Gateway T-6330U Notebook
My window xp sp2 product key not work. please help me to solve my problem.
Where as I really cannot directly give you an XP product key do to copyrights I'd love to help you out still. Go to www.keygenguru.com and search for your product type. You will find a working key in no time.
May 08, 2010 | Microsoft Windows XP Professional for PC
Can not install window xp
Your laptop probably has a SATA hard drive, windows XP only provides with PC's/laptops with a PATA hard drive.
You have to make up your mind what your really want to do.
1) Do you want a dual boot machine, working off XP and Win7?
Here's one web site:-
http://webtrickz.com/how-to-install-windows-xp-over-windows-7-in-a-dual-boot/
2) Do you want to replace Win7 with XP.
Here's a web site which covers that :-
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
May 04, 2010 | Lenovo 3000 N200 Notebook
Aspire 4520- Windows 7: Webcam does not work properly
windows 7 has a compatibility program built in for addressing those issues from the previous operating system(XP)
go to start and in the search window
type in compatibility
this program will help you by running the program to test its functionality,
it will bring up a list of programs and ask you to select the program your having issues with,
then it will give your operating systems and service packs to test against,
at the end it will ask you if you want to save these settings.Y/N?
If the program runs ok then save the settings and it should continue to work from there.
Shut down and restart should embed these settings ,
Test again for function,
If no luck run the program again
You say that your system is dual booting,why?
windows 7 leaves XP for dust,
remove xp its taking up valuable space on your hard drive and possibly interfering with your systems operations,
Normally the hard drive will only allow one operating system on it,even if you have partions.
Fine tuning is all your looking for so let us know your outcome thanks
If you do a windows back up
which system is it going to back up?
normally it will write over the last backup you made and the new one replaces it,
Cheers MISTERDJ
Apr 12, 2010 | Acer Aspire 4520-5582 Notebook
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I formated D: drive than also first time starting two option xp or vista than I want vista's option remove...
Boot to Vista. Then
  • right-click "my computer", then "properties".
  • click the "Advanced" section (Vista: on the left side bar).
  • In the section that says "Startup and Recovery", click "settings".
  • Under "Default operating system", choose "Windows Vista".
  • REMOVE the checks next to "Time to display list of..." and "Time to display recovery options..."
  • click ok to everything.
Now you will need to remove Windows XP.
IMPORTANT: for the next step make sure you boot to Windows Vista. Otherwise you could corrupt your computer.
  • Go to "Start", "Control Panel"
  • Open "Administrative Tools"
  • next, open "Computer Management".
  • On the left, there's a side bar. Under "Storage", click "Disk Management".
  • Now, If windows XP is on drive C:\,
    right click C:\ and select "Format"
  • Click "OK".
hope this helps.
Aug 04, 2008 | Microsoft Windows XP Professional
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I D: is format than also first time starting two option xp or vista than I want vista's option remove please...
hi,
To remove starting option boot with XP and go to run type cmd. then go to c: prompt. type edit boot.ini and remove the line that refers the vista. and save it.
Aug 03, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Dell Latitude D600 Notebook Logo
94 people viewed this question
Alun Cox
