Question about Canon Office Equipment & Supplies
NOT PRINTING TO END OF PAGE - Canon Office Equipment & Supplies
Change the ink, and deep cleaned the heads
gerryklei
Posted on Jun 05, 2008
Pcl XL ERROR ILLEGALMEDIASIZE
When printing from Adobe XI in Windows 7, ensure "Choose paper source by PDF page size" is unchecked, in the File/print dialog box.
Aug 17, 2012 | HP LaserJet 4050tn Printer
How to stop Lexmark C540dw printing instructions for two-sided printing
I had same issue. I checked two sided printing, but wanted it to take the paper back in to the printer automatically. I did not have the duplex option selected in properties and it was showing how to do it by feeding the pages manually. Go to printer properties and printer preferences and I think the tab labeled page layout, you may have to select the advanced button to find the 2-sided options for flipping short end or long end. (you want flip on long end if you want the top of page 2 to be on the opposite side of page one. Other wise, flip on short end will put the top of page 2 opposite from the bottom of page 1). however, AUTOMATIC 2-sided printing will not work unless your model has the duplex printing feature. In that case you just need to go to properties and un-check two sided printing and check one sided printing. That way it will not keep wasting paper and showing you how to do it manually. So you don't have to do it for each print job make sure you change it in printer preferences so it does not keep trying to do 2 sided printing. If there is a job you want to print 2 sided then just select it in properties for that particular print job.
Apr 29, 2012 | Lexmark C540DW Color Laser Printer
HL 4040CN is printing with a pink tint, it also says drum end soon and has said that for a while. What sould I do?
I have a similar problem now: magenta stain over the entire page when printing anything with any color (even just a hyperlink); B&W text is no problem.Not the PC; even the Demo Page from the 4040 menu does this. Updated the 4040 firmware tonight to latest (1.24, etc), but no better.Recently replaced the Magenta cartridge (official Brother cartridge), though saw this problem near end-of-life of the previous Magenta cartridge. Drum Unit status is 42%, so not expected to be near end-of-life.
Nov 28, 2011 | Brother HL-4040CN Laser Printer
Printing error occurs when printing off internet. It will print my emails.
If your printer is an HP, here's your fix...
You probably have an issue with the Smart Web Printing. Go into your add remove programs in control panel (sorry , you didn't specify the OS, so I am quoting XP here) and remove smart web printing.
Ya, that software has caused many an HP tech support specialist no end of trouble.
I eventually told people to start removing it (not exactly company policy) and go figure, everything would start working perfectly!
(But don't tell HP that, it's an "undocumented" solution!)
Feb 24, 2011 | Office Equipment & Supplies
What will be cost per page of printing in hp lasure jet 2600
This is going to depend greatly on what type of printing you are doing as well as if you use OEM HP toner cartridges or go with a cheaper aftermarket cartridge. At the low end, this machine will cost you 2.5 cents per page for Black & White and 15 cents per page for Color. On the high end it will be closer to 5 cents for Black and 20+ cents for Color. The percentage of toner coverage will also obviously effect you per page printing cost as a page with more coverage is using more toner than one with less coverage. Keep in mind that the stated yield that each cartridge will produce is based on an industry standard of about 5% covergae which is not much when compared to the typical printing of most users.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 08, 2011 | HP Color LaserJet 2600n Printer
(Lexmark Optra T 630 is printing a blank page at the end of every print job
Hi there, what program(s) are you printing from? This can often be caused by a Word doc having extra carriage returns at the end of the document which carry onto another page. These arent normally visible unless you click on the Show/Hide (or "paragaph") ¶ symbol to display formatting marks.
Tommikat
Dec 07, 2010 | Lexmark T630 Laser Printer
An extra page with al the details about the page is being printed
Does this happen when you print a test page ?
What programs does this happen from?
Microsoft office... ect.. Try printing from a different program, and let us know if the extra page of details prints or if it is just one program
Jun 25, 2009 | HP LaserJet 1020 Printer
Printing blank page at the end of every printing job
Hi Keren,
1) Are you sure it is the printer, not the software application ?
Try printing a single "Hello World" message from "Notepad"
If there is no blank page at the end of it, the problem is in
the specific software app: Office, Word, Excel, etc...
2) What application are you printing from?
a) Check the page and print setup.
b) Make sure the application's "page size" and the printer's
paper size are consistent. Pay special attention to
metric paper sizes vs English:
E.g. A4 vs Letter
If the page with margins is bigger than the paper, it will
generate a new page, even though there are no visible
characters on it.
c) Check the print margins within the page setup:
In MS-Office: File ---> Page Setup --->
d) Add a single character to the very bottom of your
document, and see if it wraps around onto the last page.
Microsoft office applications are notorious for wrapping
the last PARAGRAPH character onto the next page if
it does not quite fit onto the paper.
e) if you are using MS WinWord, go into options and set it
to display all special characters:
Check to make sure that there are no page-breaks at
the end of the document.
Also look for extra paragraph marks/ carriage returns,
and check the format settings on the last paragraph
mark in the document:
Page brake before...
Keep lines together ....
Widow and orphan control ...
which can cause the last paragraph mark to generate a
new page. If the last paragraph mark is not formatted
the way you want it, make sure that you save the
TEMPLATE after you change it, since this is the
DEFAULT setting for all new documents.
Finally it is also possible for Windows applications to look
different on the screen than the final print due to small
(but cumulative) True Type Font (TTF) computation erros,
such that a 10 page document on the screen can actually
page-split in weird places printing as 11 pages.
I have the identical model of printer, and it does NOT seem
to have any settings for printing banners or adding separator
pages, at least not in my printer driver, but this is NOT to say
that the applications you are using are not causing this
problem.
I hope this gets you started.
Please rate my answers.
Martin
Jul 01, 2008 | Brother HL-2070N Laser Printer
Prints a decription of my print job on one page ... additional unwanted page.
It sounds like you are printing from Word 2007. Go to the Office Button, Print, Print, Options and under "Printing Options" uncheck the "Print Document Properties" box.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jan 22, 2008 | HP OfficeJet 7310 All-In-One InkJet...
21 people viewed this question
old marine
old marine
