Question about Danby Silhouette DWC512BL Wine Cooler
Danby Silouette DBC 514BLS . The temperture shows real temp at 60 degrees while the left side has 39 degrees. I just turned off the inside light thinking that may be the problem , but the temp has not dropped at all in 15 minutes. Any ideas?
2 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: Danby model DBC514BLS. Temp
The problem you describe it seems to be from a dusty condenser so you need to remove the grill on the bottom and also at the back and using an air blower, or a vacuum and brush in order to clean the condenser coil for all the dust . The dust is blocking the sorounding air to cool down the condenser and litle bu little is loosing its efficinecy. Of course this is the most frequent case by 90% so you have to do this in order to confirm thatis not due to any part mulfaction like thermostat or other parts.
Posted on Aug 27, 2011
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
My Frigidaire PHSC239DSB2 side by side's digital temperture display is flashing a 2 on the freezer side & the fresh food sides temperature went up to 47 degrees, but has no flash. What is goin
HI this is a difficult one without a visual but i would sugest u disconnect the power supply.re-connect everything again and re-start.reset temp if not pre set.and try before u call an engineer.good luck.Ali
Jun 18, 2012 | Frigidaire FRS26H5AS Side by Side...
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
My 2007 Chevy HHR 2.2L, coolant temp sensor is reading that the coolant temp is 20 degrees warmer than the outside temp after sitting for over 12 hours and the operating temp gets to 214 degrees without...
Sure the engine coolant will be warmer than the outside temperture and if the car has been sitting a long time in cold weather and the outside temperture warms up it could be the other way around. The coolant temperture sensers aren't real accurate as they are a relaitive senser beween hot and cold and the numbers reported don't have to be real just the change from hot to cold and the reching of the coolant to the operating temperture. Noe it the senser doesn't read the opertating temperture coprrectly you'll have all kinds of problems. The therostaste will try to set the temperture of the water to it's set temperture and can open or close completly to get 195 degrees F. Many times if it's too cold then the stat is bad and needs to be replaced This shows up in alot of cars first thing after winter and the first onset of cold weather when the daily tempertures vary the most from day to night.
May 06, 2011 | 2007 Chevrolet HHR Special Edition
How can you make your conditioner cool to 40 degrees
ACs are designed to cool down to about 68^F, don't think it has a chance of doing what you want w/o re-engineering the system which is not really an option.
Sep 26, 2009 | Danby DAC9003D Air Conditioner
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Problem with digital thermostat
you have to decide if the fridge is faulty or the thermostat
if you think it is the thermostat thet bridge out the switching contacts that make the compressor run
question
is the compressor running constantly
is the cooling fan working
is the condenser blocked with dirt
if 1 of these are at fault then the fridge is not going to drop the temerature
Mar 07, 2008 | Refrigerators
Temperature light control (kegerator DKC645BLS)
Not sure u have a problem.. all appliances dont HOLD a certain.. Temp.. They cycle.. come on for awhile reach a temp the shut down.. goes so low the comes back on... the middle of the cycle is the avarage temp... yours being 36 from what you posted
Sep 04, 2007 | Danby DKC645BLS Compact Beverage Cooler
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Danby Silhouette DWC512BL Wine Cooler Logo
46 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Dennis Boxerman
jdthefixer
Are you a Danby Furniture Expert? Answer questions, earn points and help others
